ISX No Boost Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Red1775, Jul 17, 2024.
  1. Red1775
    Red1775 Bobtail Member
    4
    Need some help
    2011 Volvo 740 with ISX (deleted)
    I stopped at a red light and when I went to take off heard a squeal and at the top of the gear the truck wasn’t getting boost from turbo.
    Truck is not receiving any fault codes and checks are made by Cummings software computer.
    I have replaced the actuator, manifold back pressure and boost pressure sensor.
    Charge air cooler has no leaks
    Exhaust down pipe is clear
    Manifolds are all clear
    Fuel system is clear
    VGT moves freely by hand on turbo
    No cracks found during inspection
    Checked all wires, voltages and connections
    Turbo spins up to 35k RPM and actuator goes up to 90% and sets at around 70% on highway test with truck going 70-73mph
    Manifold is only getting 2.9 pounds of boost.
    Anything thing else to check or suggestions?
    Pretty near the end of the rope on this one.
    Thanks in advance
  3. Star Rider
    Star Rider Road Train Member
    1,779
    18,044
    Sep 23, 2019
    Check the air intake hose for the air compressor.
    Red1775 and beastr123 Thank this.
  4. Red1775
    4
    Will do, but how would that prevent the boost?
  5. beastr123
    beastr123 Road Train Member
    2,942
    24,143
    Jan 2, 2014
    Moose Jaw SK CAN
    There is an open connection to feed filtered air from the turbo into the air compressor.
    It is a standard thing to check when looking for a turbo pressure loss especially if the loss is only at higher pressures as a hose can split and still seal up to 5 to 8 pounds pressure.
    Red1775 Thanks this.
  6. Red1775
    4
    Thanks for explaining I’ll check that.
    Is there any value in running the overhead?
  7. Red1775
    4
    Checked and no issue.
