Isx repairs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NEWMAN67, Oct 7, 2013.
  1. NEWMAN67
    NEWMAN67 Bobtail Member
    27
    Oct 11, 2011
    SCOTT CENTER,PA
    How much do u think its gonna cost to have jakes rebuilt, new head gasket, and rods and mains done on a 06 isx 500.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Mains and rods are bout 1200 head gasket bout 3000 jake rebuilt not so bad probably patrs only which is just oring pretty much if u remove the head probably better to send it out to get the cam bearings done as well cuz they wear out bad on isx
    NEWMAN67 Thanks this.
  4. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    For my C 13 KCB the labor was only $ 850,after the Head was in A shop,o-rings,sleeves,new Thermostat with Oilchange ,filters,Total little more then $ 2100 i think,was a good deal for me with Tax
  5. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    I Think the Isx is cheaper then a Cat
  6. black ultra
    black ultra Light Load Member
    62
    13
    Feb 16, 2012
    conroe tx
    I'm guessing that you haven't ever worked on an isx Cummins!!!????
    VisionLogistics Thanks this.
  7. gerardo1961
    1,746
    613
    Feb 21, 2010
    Miami
    Never,only i think de Acert is not a easy engine to repair,is only my opinion iam not a Mechanic
  8. NEWMAN67
    27
    Oct 11, 2011
    SCOTT CENTER,PA
    got a estimate of 6800.00 that's with a new radiator also.
  9. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    ISX heads are very labor intensive to remove and should never be compared to any other engine. ISX's are dual overhead cam design. Both cams have to come out to get to the head bolts. The cams do not come out through the top. They have to be slid out the front. Front cover and gear train have to come apart and the rad has to be removed for access/clearance. Not cheap.
    VisionLogistics and logtrucker25 Thank this.
  10. NEWMAN67
    27
    Oct 11, 2011
    SCOTT CENTER,PA
    should have smoke out the stacks by Friday, waitin 4 radiator to come, said everything looked good when tore apart. thanks for the posts.
    Heavyd Thanks this.
  11. NEWMAN67
    27
    Oct 11, 2011
    SCOTT CENTER,PA
    well I got truck back and after the jakes were rebuilt it still is not workin rite. they changed one solenoid and all O-rings. today I took it back and we went through a bunch of different test. took harness apart at valve cover to find out that with a tester the solenoids worked that way but not when the harness was hooked up. next we tested all switches and all was good. next he took end of harness apart and found that wire was getting juice from ecm. so he figures I need to go to kw to c if they have a test ecm to hook up to c if the ecm is not sending a signal to solenoid. also hooked up to insite and it showed only one stage working.
