Jake brakes Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Truvker dad, Aug 11, 2020.
  1. Truvker dad
    Truvker dad Bobtail Member
    14
    1997 detroit 60 series engine The jake brakes keep coming on even with jake brake switch in the off position .I already changed the switch. Any knowledge of this would be greatly appreciated.
  3. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    If its in the "on" position, its supposed to be coming on
    LameMule Thanks this.
  4. Truvker dad
    14
    I meant to say off position (pardon me)
  5. Truvker dad
    14
    97 detroit 60 series.Jake brake keeps coming on even with the jake brake switch in the off position.Any help would be appreciated.Thanks
  6. AModelCat
    164,427
    Sounds to me you've got two possibilities:
    A harness/wiring issue. If you can plug in to the truck you could see if something is commanding the jake on. Maybe a short to power on the jake solenoid wire, actuating the solenoid when the jake is not commanded on.
    Other possibility could be an issue with oil getting past the solenoids on the jake heads, actuating the jake pistons. Not sure how likely this scenario is but I could see it happening.
    magoo68 Thanks this.
  7. Truvker dad
    14
    My mechanic says it can't be the jake wiring harness he keeps say ecm and i just don't think so.
  8. AModelCat
    164,427
    It could be the ECM but it is very unlikely. They have a very, very low rate of failure.
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Unplug the switch and see if issue persists . If it doesn’t then new switch is faulty or wrong one maybe.. if issues persists I’d check wiring closely to see if it’s rubbed through and power is crossing over.
  10. Truvker dad
    14
    Thanks for your feedback I will have a look at it this weekend
  11. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Hook a test light in to the wiring going In to the Jake solenoids.
    If you have power there when the the problem occurs it’s an electrical problem.
    If the problem occurs with no power there it’s a hydraulic mechanical problem under the valve cover.
    shawnhhllc and magoo68 Thank this.
