John deere
Discussion in 'Trucks [ Eighteen Wheelers ]' started by zinita17601, Mar 3, 2017.
  1. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    I picked up a 1966 5020 john deere tractor going to the baltimore port.
    The guy who loaded the thing assured me that the tractor runs and all it needs a jump or new batteris,he used a forklift.
    Went home swapped the batteries,turned the key on and hit the start button,it cranked couple times than the starter just kept spinning even without me hitting the start button.
    Unpluged the positive wire and when i try to plug it back it sparks really bad and the starter starts to spin non stop.
    Anybody knows what im doing wrong or what i need to check?
  3. kwswan
    kwswan Road Train Member
    2,026
    11,060
    Jul 26, 2009
    mcminnville,tn.
    6 volt or 12 volt batteries? Makes a difference on how you hook them up.
    SAR Thanks this.
  4. wore out
    wore out Numbered Classic
    17,294
    214,419
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Most likely the starter solenoid is hung in. Unhook the small wire marked S on solenoid then hook batteries up and see if it still does it. If it does pull the starter. (have fun with the back bolt) if it doesn't find where the S wire is shorted to power.
    cke, Oxbow, Kenworth 4life and 2 others Thank this.
  5. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    12 v hooked in series,its a 24 v system
    Oxbow Thanks this.
  6. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    The john deere dealer told me its a faulty solenoid,can u explain why the starter doesnt engage
  7. 25(2)+2
    18,759
    45,962
    Sep 18, 2006
    the road less travelled
    The solenoid pushes the starter pinion into the ring gear and energizes the starter motor when it gets the signal voltage from the starter switch.
    Sounds like it engaged the motor but doesn't disengage, and the pinion isn't being pushed into the ring gear.
    cke, Oxbow, SAR and 1 other person Thank this.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    A sharp tap with a bar or hammer can free it up? Bump it on starter not sol. to keep it looking good for oversea buyer
  9. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    I unhooked the wire to selenoid,starter still spins non stop,hit it with a hammer.nothing helped. I dont care about the buyer overseas,i just wanna drop it running at the port.
    Can i replace the selenoid or do i have to replace the whole starter
  10. wore out
    17,294
    214,419
    Jun 5, 2013
    Yes you can replace just the solenoid
    BoxCarKidd and Oxbow Thank this.
  11. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Can u please tell me how?it looks like the selenoid is built into it
