Jumper cables
Discussion in 'Questions From New Drivers' started by Panman49, Dec 16, 2019.
  1. Panman49
    Panman49 Bobtail Member
    14
    15
    Sep 4, 2019
    Any recommendations on booster cables? Aluminum/Copper clad or just Copper or does it matter? What gauge cable should I get? Thank you
  3. krupa530
    krupa530 Light Load Member
    296
    1,140
    Dec 3, 2014
    Orem, UT
    Polar wire.com. jumper cables
  4. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    The lower the gauge rating, the better
    Nothereoften, Panman49 and Bean Jr. Thank this.
  5. Moose1958
    Moose1958 Road Train Member
    15,290
    33,957
    Dec 17, 2010
    Williesburg, Virignia
    I always just used a set of plain copper wire cables. I kept them behind the seat of my POV. I carried jumper cables in my truck for a long time. Back in my drive-a-way and repo days sometimes I had to use them. About 12 years ago I stopped carrying cables in my truck. I have seen what seems like simple things like shorting out a starter cause an electrical surge that messed up a truck electronics equipment. Owner operators might keep them. But from that period of time till I retired no cables or chargers touched my battery case unless it was a company mechanic or someone called to come out to help me.
    Lepton1 and Panman49 Thank this.
  6. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    When I drove a low-bed, I had a set the boss made from old welding cables so I could jump start equipment without having to get too close.
    austinmike, Panman49 and AModelCat Thank this.
  7. AModelCat
    164,483
    The arctic cable flexes pretty good too in cold weather.
    Panman49 Thanks this.
  8. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    I make my own from welding cable, custom length, use heavy-duty clamps, crimp, solder and heat-shrink the ends. Thirty-plus years and they're like brand new.
  9. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    If you dont have any extra welding leads laying around go get some 00 cable to make your own.
  10. Tall Mike
    Tall Mike Road Train Member
    7,672
    36,725
    Aug 20, 2014
    New York State
  11. Panman49
    14
    15
    Sep 4, 2019
    I was just checking them out. They ain't cheap. Going to look around and see if I can find a used set!!
    Rideandrepair and Tall Mike Thank this.
