Junction box diagram
Discussion in 'International Forum' started by eng.moh.4u, Feb 10, 2017.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    Hi
    I have 7500 truck model 2005 and I am missing the junction box cover. Can any one help me to find this diagram for this Fuse/Junction box, because I need to know which fuse for backup light
  3. snowblind11
    snowblind11 Bobtail Member
    23
    13
    Feb 6, 2017
    What is your last 8 of the VIN?
  4. snowblind11
    23
    13
    Feb 6, 2017
    You are looking at the engine bay fuse panel. You won't find any fuses for the back up lights in there. On the passenger side behind the dashboard there is another fuels panel and this is where most of the cab lighting fuses. Depending on which transmission you have it might be fused internally in the body controller. I would need your last 8 to find out for sure.
  5. eng.moh.4u
    40
    4
    Jan 13, 2017
    Last 8 ( 6J245745 ) and transmission is Eaton FR0F
    And please if you have also pic for diagram for that engine bay fuse panel cause may help me in further problems
  6. snowblind11
    23
    13
    Feb 6, 2017
    Here is a link that you can download the complete wiring diagram for this chassis. Also I have the operators manual which will give you the fuse breakouts for both the engine bay and passenger side inside fuse panels.
    https://drive.google.com/drive/folders/0B2sLAOb4bXKFSDV3bDZRQjZvRlk?usp=sharing
    Let me know if you have any other questions.
    eng.moh.4u Thanks this.
  7. eng.moh.4u
    40
    4
    Jan 13, 2017
    Many thanks for your help those wiring will really help me
    But when I compared the fuse chart (Interior and Engine)in service manual and the truck I found no relation between them as in below pic
  8. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    IMG_1126.JPG This diagram seems really hard to find, so I took a picture of one.
  9. snowblind11
    23
    13
    Feb 6, 2017
    On page 88 is where you will find the wiring... Attached in the diagram. There should be a 2 wire switch on the top of the transmission... with the key on and you jump the wires, does it turn on the lights and backup alarm if it is installed with one?
  10. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    Any chance you have a similar link for a 2011 Prostar with VIN BN288806? Thanks,
    Frank
  11. snowblind11
    23
    13
    Feb 6, 2017
    You bet... Here you go.. ( https://drive.google.com/file/d/0B2sLAOb4bXKFc3FkdU9SR1ctVzA/view?usp=sharing)
    Also you can purchase a USB stick with all the manuals for international chassis. There about $600 or so, but if you do alot of internaitonal truck repairs its worth it. It has all the electrical, chassis and engine manuals. Along with operator and maintenance manuals. Just have to ask your local dealer to order
    USB drive, OnCommand Service Information (OCSI)
    Product Number: 0000314661
    From the online tools catalogue.
