just need advice:(
Discussion in 'Experienced Truckers' Advice' started by nmatam2004, Apr 6, 2017.
  1. nmatam2004
    nmatam2004 Bobtail Member
    19
    9
    Apr 6, 2017
    Hello, so just got my licence 6 months ago but what really caught my attention was hazmat,i've been trainning for 2 months with fuel and i feel like i'm almost there,have gone up hill a couple of times and twice i loose complete speed and have to start all over again wich is nerve wrecking,with my trainner getting frustrated makes it hard sometimes to concentrate,also we have to park the truck reverse its a tank tractor and trailer,n i know that when is semi if you go left tank goes right, go right goes left, i cannot find the way on this tractor/trailer can't figure out how to control the back trailer,for some reason i feel like my trainner is not helping in that area.. have tried it like 10 times n cannot figure it out i can load and unload, drive all the time loaded and unloaded but this errors i just cant fix them and its the only thing holding me back to driving and start working on my own...thank u for your time.. sorry for the grammar :/..
  3. dptrucker
    dptrucker Road Train Member
    4,703
    3,239
    May 14, 2012
    adelanto,ca.
    Why are you backing up doubles?
    DTP Thanks this.
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Are we talking about a tractor and 2 trailers or a long straight tanker truck with a short tanker trailer behind it?
    As far as the other issue, are you saying you're having troubles shifting up and/or down?
  5. nmatam2004
    19
    9
    Apr 6, 2017
    Tractor and trailer,my biggest issue is reversing, i cant seemed to understand the effect of the back trailer not the truck.
  6. nmatam2004
    19
    9
    Apr 6, 2017
    No i call it doubles because is two.. but no the first tank is mounted to the chassis so its not considered doubles.
  7. nmatam2004
    19
    9
    Apr 6, 2017
  8. nmatam2004
    19
    9
    Apr 6, 2017
    Just fixed my post,i know was confusing.
  9. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    First of all, we need clarification on the type of rig. You say there is a tank on the truck, and you're pulling a trailer. What kind of trailer? Is it a 5th wheel? Or does it connect with a pintle hitch at the rear of the truck? If it connects with a pintle hitch, are the trailer axles fixed or does the front axle steer?
    I ask because if there is 1 pivot point between the truck and trailer, you'd back it one way...and if there are 2 pivot points (front trailer axle "steers"), you'd tackle it a little differently.
  10. passingthru69
    Truck and pup trl. West coast setup.. You have to remember you have 2 piviot points. 1 at the end of the trk. where the draw bar hooks to the trk. then on the pup turn table.. Try thinking like your just backing up the trk. by itself.. easy turns, not fast turns on the wheel when backing up
    Logan76 and noluck Thank this.
  11. nmatam2004
    19
    9
    Apr 6, 2017
    Theres no fifth wheel. On the trucks chassis tank is mounted, the trailer is pulled cant seemed to understand how to control the back tank when backing up.. its not the same as a semi.
