Kenworth cab rivet rust
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W923, Nov 22, 2022.
  1. W923
    W923 Road Train Member
    1,384
    4,255
    Feb 28, 2022
    I am looking at another older w900 and several of the rivets that hold the cab panels together are rusting ( mostly on the back wall of the cab) What is the best solution to this problem?
  3. pavrom
    pavrom Road Train Member
    3,193
    7,317
    Apr 29, 2012
    NE illinois
    When you getting older do you color gray hair ?!
  4. Last Call
    Last Call Road Train Member
    7,568
    45,908
    Mar 15, 2021
    Rusting ? .or do you mean corroding ?
    The best solution to that issue is..Don't buy it ...Walk away ..
    To fix that problem. Correctly is not cheap..is not easy.. and its like Herpes it will stay with you forever
    HoundDog7, W923, BoxCarKidd and 2 others Thank this.
  5. Arctic_fox
    4,343
    23,399
    Sep 16, 2016
    Pretty much. Your likely looking at between 5 and 10k to get it done right maybe more if the damage is extensive enough. And thats with just surface rust. Gotta sand prime paint and cleae coat. If the rivits are corroded you gotta replace them which is a whole ordeal in and of its self. Hell after my wreck i popped just 8 rivits on my cab on the impact side where they bounced off. on the repair quote just that was listed at over 10k. Was actully cheaper to reseat my front axle and replace the entire steering linkage then the body work.
    W923 Thanks this.
  6. Last Call
    7,568
    45,908
    Mar 15, 2021
    Those aren't rivits anyway they are huck bolts .. I forgot to state that in my 1st post
    HoundDog7, W923 and Bean Jr. Thank this.
  7. W923
    1,384
    4,255
    Feb 28, 2022
    ???? Went right over my head
  8. W923
    1,384
    4,255
    Feb 28, 2022
    Yep you’re right, they’re huck bolts but I figured everyone would get the idea with less confusion. And these particular ones are steel and rusting as in red color like a frame so I didn’t think corroding was the right term. Sounds like the bottom line is look elsewhere…
    Last Call Thanks this.
