Kenworth T2000
Discussion in 'Ask An Owner Operator' started by NewHauler, Aug 8, 2007.
  1. NewHauler
    NewHauler Bobtail Member
    21
    Jul 9, 2007
    New Joisey
    My partner and I are going to look at a 2003 Kenworth T2000. The truck has @550,000 miles on it. Truck is equipped with a CAT 550, 18 spd, Rockwell 46 rears, 3.91's, wet kit, etc. The vehicle is alleged to have a good documented maintenance history, and the truck is in overall nice condition according to the pictures. The owner is looking for @ $40,000. Is this a reasonable price for a truck with this set up?? Are there any gremlins for this truck that I should be aware of or something not too obvious?? The anticipated use for the truck is garbage hauling. Thanks in advance for the help.
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    Big motor for garbage hauling! Also those rear ends are too high for a cat motor. Cats like low rpm's. My 475 cat with the same rear gears averages 5mpg with a light 20k load. Loaded to 80k and running 75mph will get me a whopping 3.8 to 4mpg.
    A cat can get decent mileage (not great) but they need low rpm. That 18 speed will help a bit but not much.
  4. Bullwinkle
    Bullwinkle Medium Load Member
    594
    29
    Jun 11, 2006
    Texas
    These trucks have a bad problem with big time windnoise through the doors. You can literally see the wind pushing the door open and closed, and it gets really bad in a crosswind.
    Might not be bad when they are new, but for a 2003, I would pay attention to this. Might not sound like a big deal, but it will be after putting up with the noise for 2-3 hours straight.
  5. Pete_379X
    Pete_379X Super Chrome
    1,006
    124
    Jul 4, 2007
    The T-800 roll off I ran for my cousins business has 4.33 rears and 425 cat. Needed every bit of them at the landfill. Mmostly ran 1st with the bed up and when it rains. The truck pulled like a monster. Fuel mileage sucks... top speed was about 72mph and that was screamin...
    The T2000, I've heard some good and bad about them, but not too much. I figure its about like any other truck.
  6. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Raise the hood, look at the motor, and ask yourself, how in the world am I going to get in there to work on anything.
    If you can't, a mechanic won't want to either, and will charge you dearly when he has to.
    Besides, the trucks are loud, and the plastic doors won't shut tight. The floorboard is made of plastic too.
    If you are hauling mostly road, the 3.91 might be OK if you have 24.5 tires. 3.70 or 3.55 would be better.
    If you are going to be on 55 mph roads, and in the dirt some, the the 3.91 will be as tall a gear as you want, maybe even a 4.10 would be better.
    22.5 tires will gear the truck lower also.
    You don't want to be geared so high as to burn your clutch out on a regular basis trying to get moving in the dirt.
    If you are going to do both road and dirt, then get 3.70 - 3.55 with a 15 speed.
    This way you will have deep reduction for off road, and a good overdrive for the road.
  7. Bullwinkle
    594
    29
    Jun 11, 2006
    Texas
    And I am happy to say that unless something goes drastically wrong between now and Wednesday, I am making the last trip in the 2002 T2000 that I am currently driving.
    A new blue 387 should be rolling into the yard during my run to Georgia and back this week :)
  8. NewHauler
    21
    Jul 9, 2007
    New Joisey
    Thanks for the replies, it seems like I should continue my search elsewhere....
  9. ~*GypsyRose*~
    ~*GypsyRose*~ Bobtail Member
    23
    Aug 2, 2007
    Anywhere,USA
    Like has been said already, the doors are very noisy. It will get on your nerves quick! Plus if it has the bottom bunk windows, the sills and stuff tend to start falling apart and rattling. Just doesn't seem to be a well built truck period.
  10. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,908
    12,210
    Sep 17, 2006
    WY
    Park em side by side and take a good look. It'll begin to look like the same truck until you walk to the front.
    :biggrin_25523: :biggrin_25523:
  11. MACK E-6
    49,989
    237,914
    They are identical, except for the front end.
