Kenworth T800 electrical issues
Discussion in 'Kenworth Forum' started by Ramos, Mar 31, 2017.
  1. Ramos
    Ramos Bobtail Member
    4
    Hello i have a 2008 kenworth t800 ,the left turn signal on the dash won't turn off ,the light outside won't turn on unless I move the handle but the light on the dash stays light, not flashing ,just lit,also my trailer left turn signal is not working and my trailer brake lights are not working, there is no current going to the pigtail I checked for current ,any ideas ?
  3. Ramos
    4
    I meant to say there is no current going to the stop lights pin on the connection coming from the tractor but there is for all the other lights
  4. JDHIGGINS44
    JDHIGGINS44 Light Load Member
    113
    272
    Jun 29, 2015
    Waynesburg, PA
    Well the turn signal being on solid makes me think either you just put new lights in and crossed the turn signal wire with the marker light wire or odd and far fetched as it may seem I have seen the bulbs where the one filament actually breaks inside and lays across the other causing the exact same symptom. The trailer problem is more than likely not related as brake and turn signals are on a separate circuit.
  5. JDHIGGINS44
    113
    272
    Jun 29, 2015
    Waynesburg, PA
    Check your brake switch on the tractor then for power going and then power coming out with the brakes depressed and then proceed and troubleshoot on from there.
  6. Ramos
    4
    Do you think the brake lights would work on the tractor if it's the brake switch?
  7. Ridgeline
    22,723
    123,031
    Ideas?
    Yes, the body computer may be bad.
  8. Ramos
    4
    Thank you ,now I have a place to start looking for my shortage
