Kerosene smell,help!
Discussion in 'Questions From New Drivers' started by 5forFreedom, Feb 15, 2021.
  1. 5forFreedom
    5forFreedom Bobtail Member
    Feb 15, 2021
    Its continuously smelt like kerosene in the cab of our freightliner and now its night,and the smell is even stronger. My husband's back asleep and im concerned for our animals safety and ours,does anyone know what the kerosene smell is or what i should do!?
    Trucker61016 Thanks this.
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Do you have any chemicals stored that may have spilled? Anti gel, or anything?
  4. 201
    201 Road Train Member
    12,758
    26,251
    Apr 16, 2014
    high plains colorado
    Ok, ok, calm down, it's not going to blow up. Is it while it's running? You have a fuel leak, could be anything. Fuel cap(s) on? Something leaking under the truck? I wouldn't mess around in the cold, get it to a shop.
    tscottme, beastr123 and Trucker61016 Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,687
    184,135
    Aug 28, 2011
    Henderson, NV & Orient
    Yeah, that could be it.
    Spilled or leaking paint or oil or fingernail polish or polish remover.
    Any clothes that have been dry cleaned.
    Edit: Recently there was a similar smell in one of my bathrooms. Discovered it was the packaging for some new shower curtain rods. Took the rods out and threw the packaging away and the smell went away.
  6. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    If it smells it will have stained as well. Thankfully diesel isnt like gasoline. It wont ignite with an open flame. Look around. If the smell is happening when the engine is off. Look near the bunk area. Bunk heater would be the first thing to be suspect. Also, step out of the truck and look at the ground for fresh puddling of the fuel on the ground.
    Yet be aware. Some bunk heaters only stink at startup and your nose may not be used to the startup smell.
  7. Flint1
    Flint1 Road Train Member
    1,159
    9,922
    Sep 4, 2019
    Alberta
    Fuel treatment (eg howes or power service) reeks of kerosene if spilled in the cab. 1 drop is all it takes..
    tscottme, T.Rucker, Isafarmboy and 3 others Thank this.
  8. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Check the jockey box under the bunk for a leaking container of something like no-gel. Years ago I had one break open and I wound up turning in the truck for another one because of the smell.
    lovesthedrive, baha and street beater Thank this.
  9. Numb
    Numb Crusty Curmudgeon
    4,309
    10,226
    Jan 30, 2012
    Charlotte, N.Carolina
    did somebody spill/step in fuel at the fuel island.
    lovesthedrive and Trucker61016 Thank this.
  10. scott180
    scott180 Road Train Member
    1,217
    4,222
    Dec 10, 2012
    Tooele, UT
    Diesel and kerosene are close to the same smell. Be safe and only take educated risks.
    I drove a Freightliner that was leaking fuel on top of the engine 10 miles to a shop. I knew it wasn't going to light. Mechanic agreed but it was my choice.
    Sleeping around it I would not do. I'd be worried about the fumes. Get to a shop and then buy them pets a steak to make up for the bad smell.
  11. AModelCat
    164,498
    Pop the hood and look for a fuel leak.
    Cat sdp Thanks this.
