Kingpin Settings
Discussion in 'Questions From New Drivers' started by daddyhusky, Mar 18, 2014.
  1. daddyhusky
    daddyhusky Light Load Member
    80
    53
    Jan 23, 2009
    Atlanta, GA
    For those of us 53' van drivers that need to pay attention when sliding tandems, here is a quick reference for kingpin settings. We all know CA is the shortest at 40' kingpin to center of rear axle, but there are a few others that aren't much longer. Some have changed recently. I hope it helps.
    Maximum Kingpin Settings per Rand McNally Atlas 2014
    California- 40' kingpin to the center of rear axle
    D.C.- 41’ kingpin to the center of tandems
    Florida- 41' kingpin to the center of tandems
    Illinois- 42' 6" kingpin to the center of rear axle
    Maine- 43' kingpin to the center of rear axle (on designated routes only)
    Michigan- 37’-41' kingpin to the center of tandems
    Minnesota- 43’ kingpin to the center of tandems
    Tennessee- 41’ kingpin to the center of tandems
    Vermont- 41' kingpin to the center of rear axle
    Virginia- 41’ kingpin to the center of tandems
    West Virginia- 37' tractor rear axle to the trailer first axle
    Wisconsin- 41' kingpin to the center of rear axle
    flatbedcarrier Thanks this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,925
    18,921
    Nov 1, 2010
    Burnsville, MN
    How can a 'maximum' use a 4 inch range?
  4. jsprocket
    jsprocket Heavy Load Member
    830
    262
    Nov 4, 2013
    Columbus, GA
    So glad my stuff doesn't slide.
  5. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    Different type trailers.
  6. Scuby
    Scuby Heavy Load Member
    816
    235
    Mar 10, 2007
    The best way to avoid worrying about bridge laws is to set up and load a 53' trailer for Calif. If the person loading the trailer knows what they are doing they can do this every time.
  7. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    They have a maximum AND a minimum. The minimum is what started all this years ago when bridge engineers were concerned about too much [gross] weight being concentrated in a small area. The maximum is as much about maneuverability around corners and narrow streets as anything else with the introduction of 53+ foot trailers
    daddyhusky and 123456 Thank this.
  8. rank
    rank Road Train Member
    9,919
    113,509
    Feb 11, 2010
    It's "wheel base"....or "KP to center of tandems".
    "Kingpin setback" is the distance from the KP to front of trailer.
    "Kingpin setting" kinda confuses things. Not trying to be a ####....just saying.
    blade, daddyhusky and MNoutkast Thank this.
  9. MNoutkast
    MNoutkast Medium Load Member
    441
    151
    Feb 24, 2012
    Elk River, MN
    Bridge law is MINIMUM not maximum.
    King pin to tandem is MAXIMUM length.
    It is possible to be legal on king pin length but not legal under bridge law. Example: a truck weighing 80,000 must have a length of 51' from center of steer axle to center of rear most axle. So a truck fully loaded with the tandems all the way forward would meet kingpin requirement (under 40' in California) but be only 50' total and be a violation to federal bridge law.
    daddyhusky Thanks this.
  10. daddyhusky
    80
    53
    Jan 23, 2009
    Atlanta, GA
    Thanks for the input. Yes, wheelbase is more accurate, measured kingpin to tandem axles. As a 53' van driver, I definitely don't have time to worry about the exact calculations of the bridge law; I just need to get weights, count pins, and move those axles till DOT is happy. For a quick reference, I like this list.
    Unfortunately you don't have much control of how it is loaded, except to get your weight, slide your wheels, and then take the freight back and tell them to rework it if necessary. I have not had to do that yet luckily, but I got darn close with a 79,500 load in CA. Idiot distributor put a 1800 cat litter pallet on the back end of my trailer, and of course no scales for 27 miles. I measured the 40' to the middle of tandems instead of rear axle, which was 2 1/2 feet off. DOT pulled me in, said "move your tandems, but good luck with the weight." I broke the seal, broke down the pallet, and moved 1800 lbs of cat litter to the front end of the trailer where there was room on either side of a single pallet at the nose. It took two sweat-filled hours and caused a little damage to some cat litter bags and a few cases of SOS pads, but I scaled out with no citation, the lumpers rebuilt the pallet for me, and the customer was none the wiser when I put the seal in the back and just docked. Lesson learned.
  11. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    If they really are concerned about the bridges out there they should make earthquakes illegal.
    EternalHopez Thanks this.
