if you have balancers on steers and kingpin is bad will tires still be good my tires are good but 1 shop said my kingpin messed up. i had my dad look and he said kingpin is good. i dont see any issues. i had it checked october and no issues. before i go to shop monday i just want to know if maybe i by having centramatics thats why my tires arent showing any issues. ive heard if kingpin bad, then tires are bad.
kingpin
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4noReason, Jun 16, 2018.
A king pin will typically have to get quite a bit play before noticing any tire wear related to camber. If the toe is nuts on it may show no wear even with a little slop in the bushings.
Always check them before greasing as the grease can take up a small amount of slop, until its loaded again anyhow. -
I don’t understand what the op is trying to say. Is he or not having funny tire wear ? I’m trying to get a clear understanding, but can’t.
King pin wear you either see deep grooves in the king pin itself, if not, you can adjust the fifth wheel to remove the slop/play. Also, if all is good, check the plate to make sure you don’t have any dry spots. Keep enough lube on it. -
no tire is fine. my shop at my company told me kingpin is bad. but i dont understand how if my tires are in good shape. thats what im sayimg
Ask this shop one question. How much the kingpin play is off from manufacturer specs? He-he.
Enjoy the deer in headlights face. -
He is about front axle kingpins
did you ask them to show you the play in the kingpins. always ask them to show you when they mention something like that to you. you can check it yourself if you have a bottle jack and a tire iron. stick the tire iron threw a hole in the rim and grab the break drum from the outside and pry on it. if that makes sense, king pins may be bad but you may not get enough leverage trying to pry between the ground and the tire.
