Knowing when to leave
Discussion in 'Experienced Truckers' Advice' started by cat2, Nov 13, 2015.
  1. cat2
    cat2 Light Load Member
    56
    27
    Jul 14, 2012
    Massachusetts
    I would like to share my experiences with all of you at the last place I worked for. I had started back around August of this year doing bulk tanker work. So, after about a week of training I was given a truck with no ac. Ok, I ran it for a month or so. I was then given another truck with 750,000 on it. But, it was in good shape. There where days when I worked 13-14 hours a day. Because we would have to load at the rail yard and also deliver. Some companies ran 3 shifts. Anyway's my first incident came when I got pulled into a weigh station by DOT and was told I could not pull the trailer. Had to leave it there as there was too much play in the 5th wheel.
    So, when I got back I did a write up. The mechanics , I will use the term lightly put shims in it and it was put back into service. I get it back and notice they don't grease it? Good indicator somethings wrong with this picture. 2 weeks go by and my dog is leakin coolant. About a gallon a day. I have a dry rotted line. I bring that to the attention of the transportation mgr & mechanic like show it to them. He tells me to run it and they would "fix it later". Well sure enough it lets go and they have to call road service and fix it at some truckstop. He the transportation mgr told the owner that he was gonna fix it over the weekend. No one told me that, so I never dropped it off at their shop. Sounds like being thrown under the proverbial bus.
    Next , I found a broken rear spring. I told them about it. I also wrote up all 4 rear shocks where loose. They fixed the broken spring but left the shocks all loose.
    While the truck was down for a week I was given a spare. I was pulling about 48,000 up a hill when the front wheel on the drivers side came loose and went in another direction. So, now I am down on the brake pads, I mean everything went. Some 4 wheeler called the state police on me. I drove on it to get it off the road. not too far. The state police called DOT and I got alot of heat for that. So, I found another job . In the meantime I got into an altercation with a mgr. about all the bs I been dealing with since I started with them.
    Well, 2 day's later they fired me for that. I feel great . I am going to work for a better company doing local. My road days are over. My advise? Know when it's time to hit the road. I was lucky. If a car hit that tire I would have been involved in a major accident or someone could have been killed. But I got out ok and as they say what goes around comes around. Have a good day.
  3. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    Sounds normal truckdriver stuff to me.
    Lepton1 Thanks this.
  4. MACK E-6
    49,968
    237,730
    What is the name of this company?
    77smartin and mp4694330 Thank this.
  5. truckon
    truckon Swamp Thing
    4,774
    15,917
    Dec 16, 2011
    Like I'd tell you!
    How did the DOT notice the play in the 5th wheel?
  6. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    you are young. as a result, you didn't know any better, at first.
    what i have done, for a whole lot of years, is i drive by a place that i see wither an ad for employment, or someone tells me about. i check out (the best i can from a distance) they equipment.
    i see old, decrepit, i drive on by.
    i see shiny new, many times, i drive on by
    i see what looks like well maintained, i stop in an talk, then fill out an application
    the road test, i usually ask if that IS the truck i will be driving, if not, then it is very often an exact match to what i will be, and i can get a good idea on things.
    i usually ask to visit the shop (if they have one on site). sometimes, i do know a mechanic, sometimes, not.
    i do not want brand new, did that once, pay sucked, no benefits, BUT IT WAS a NEW truck....screw that, i cannot eat with low pay, all because they have a nut to crack, paying that thing off.
    the old, decrepit trucks/equipment, speak for themselves, and i'll leave that job for the hard up drivers that cannot find a better job due to thier past.
    the well maintained trucks/ equipment tell me at least they take care of them and make money with them, and are probably paid off, meaning i can garner a higher pay, and benefits package.
    you (the o/p) choose that job, you have no one else to blame, but your self. you SHOULD HAVE LEFT SOONER, but you did not.
    not our problem, but i will as i say, chalk that up to being inexperienced and maybe in too much of a hurry to get working....they must have sold you a "bill of goods", to get you into the door.
    now, you do realize, the possibility exists that you have PSP points for that 5th wheel..>??
    did you check into that..????
    i hope you don't..........but check into that.
    rank, Vilhiem and Ok big boy Thank this.
  7. cat2
    56
    27
    Jul 14, 2012
    Massachusetts
    have been deciding for the past couple of weeks weather to post this or not. But anyways for what it's worth, i posted it. I'm glad I'm outta there. I got a few more years to go before I hang it up .
  8. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
    Thank you for sharing. Glad things worked out for you in the end.
    :biggrin_25519:
  9. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    Sounds like the rat infested junk I had to drive when I first got into this business back in the early 80's. It was all I could do to tough it out until I had enough time in to get on with a better company. Glad you made the jump, now you know what to look out for in the future. If someone doesn't respect you enough to fix the truck, it's time to move on...pronto!
  10. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    i am glad you are out of there as well. take what you have learned from that and make sure you make a better decision(s) regarding future jobs.
  11. farmboy73
    farmboy73 Medium Load Member
    552
    686
    Oct 23, 2015
    Knoxville, TN
    G. Anthony, To someone without experience what you say above sounds like wisdom. However, I am not sure I would be able to discern what is "well-maintained" by a visual drive by just because I don't know what I don't know. For those of us without any or with only minimal experience, what are some "red flags" or other consistent things that might help us identify well-maintained equipment vs equipment that has seen its better days? I imagine you and others will have some tips and pointers that would be helpful to us.
    Thanks
    Grijon, Big Papaxx and G.Anthony Thank this.
