KW Sleeper Questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 1973w900a, Dec 10, 2011.
  1. 1973w900a
    1973w900a Bobtail Member
    20
    6
    Sep 30, 2011
    Who out there has removed an aerocab, what did you have in it for money, thank you.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    I'm not sure if this is what you are asking but I just priced up some new KW's with the EXT.cab (which is the piece that will bolt on where the aerocab sleeper comes off) and the 38" aerocab sleeper.
    That EXT cab panel was #### near as much as the 38" sleeper. I can image that KW would probably want about 3000.00 or more for that EXT. over the counter and then of course you have to paint it and install it.
    Of course if you have a buyer that will take your sleeper I would imagine that you could offset some of that. But I have been told that aerocab sleepers are about as popular as Mack sleepers.
    In other words, there not,
    Hope that helps?
  4. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    I know when I priced removing one it was going to be $4,000-$5,000. The panels from daycab conversion company to do the extended cab were over 2k I thought and they said to figure on 40-50hrs of labor start to finish. I did see one guy doing them by just cutting chunks out of the sleeper since they aren't worth much anyways.
    Sent from my Motorola Electrify using Tapatalk
  5. Pfuse
    Pfuse Light Load Member
    119
    52
    Aug 18, 2006
    La Crosse, WI
  6. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    My local KW dealer's bodyshop is always looking for good late model sleepers. Old stuff isn't worth much but they have a hard time finding newer replacements for wrecked trucks.
