KW starter issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bigguns, Jun 28, 2020.
  1. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    I swapped engines. I used my flywheel housing and my starter. The flywheel was replaced with a nearly new one. Only difference was mine had an 8 1/2” bore and the one has a 10” bore. Four new batteries. All grounds were cleaned as the engine was out. No issues before the swap.
    When I turn the key sometimes all I get will be one loud click. Bump it 2,3,4 times and it will roll the engine over.
    I swapped to the starter that came on the donor engine and it does the same thing.
    I’m at a lose at to what the problem is.
    Series 60 12.7
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I have posted before about voltage drop tests. It is not rocket science. We need a meter as we cannot see electrons flow.
    Probably something simple like a ground between the engine and frame or batteries. A simple test light will do the job. Two people make it easier.
    bad-luck Thanks this.
  4. cccoltco
    cccoltco Bobtail Member
    5
    5
    Apr 26, 2012
    Urbana, OH
    Starter relay? Different motor but mine presents the same when one's going bad...
    spsauerland and bigguns Thank this.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Does it still have the push on connectors for starter relay in battery box?
  6. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    No. All wires have eyelets and components are studs with nuts.
  7. bad-luck
    bad-luck Road Train Member
    3,430
    6,318
    Nov 16, 2013
    Baltimore, Maryland
    I had a similar issue. Truck would do exactly what you are talking about in my 379. Put a new starter in, same issue. Checked the voltage to the starter solenoid, at times was only 6-8 volts. Turned out it was the wire from my starter button to the solenoid.
    bigguns Thanks this.
  8. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    I have seriously questioned if it could be that wire or the key switch itself. I am hoping to avoid excessive searching for the problem. I am getting tired of working on an old truck. Getting old myself. By posting here I was hoping for a shortcut to the problem. I’ll report back when I have the problem.
    Rideandrepair and BoxCarKidd Thank this.
  9. bad-luck
    3,430
    6,318
    Nov 16, 2013
    Baltimore, Maryland
    I feel your pain. Hopefully it's an easy fix. I just ran a new wire to the started from the button. Good luck
    Rideandrepair and bigguns Thank this.
  10. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Well if I am working on a break down ,like I am driving it with limited tools, I might cross the battery top terminal from the solenoid to the small one on the drivers side. It should engage and spin the engine.
    That is a 42MT with the solenoid on top which you most likely have.
    If you use the screwdriver between the two large studs the starter motor should spin without engaging the engine.
    That is the kind of stuff that can ruin screwdrivers and damage threads. I do not like to recommend things that could have bad results. An example for the reason of voltage drop testing. Went on a service call for a similar problem. The starter had already been replaced. A test light between the positive battery terminal and the solenoid would light when the start button was depressed. The battery cable connector at the battery was in a sealed connector. It looked great but testing narrowed it down and I cut it open. It was all green and corroded inside.
    Love to see you have her going pics!
    Rideandrepair and spsauerland Thank this.
  11. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    That is to the large + battery stud on the solenoid. Do the same thing from a - battery stud the the big ground stud on the front of the starter.
    All you need is a test light ( old school with a light bulb ) and enough wire to bridge the span. Have someone try to start it in each case. The light should not light.
    Hold the test light on the small solenoid terminal nearest the frame. Have someone push and hold the starter button. The light should stay lit.
    Happy 4th. What did you find?
