KW T2000 Electrical Gremlins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SpeedyGonzalez, Aug 15, 2019.
  1. SpeedyGonzalez
    SpeedyGonzalez Light Load Member
    123
    59
    Dec 28, 2017
    With the engine issues solved I've started working on getting the electrical issues sorted. There aren't too many but they require a deep dive as my basic rummaging around has yielded limited results.
    1. Cabin wiring dead short, the PO seemed to have the same conclusion and tore most of the interior out trying to find it. It's killed two alternators so far by pulling the batteries low while driving and overheating the alternators. Disconnecting what I believe is the cabin ground gets rid of the short but the truck won't function with that removed.
    2. Reverse lights refuse to work.
    3. Gauge panel gauges are permanently stuck doing sweeps, previously they wouldn't power on at all. Found a white wire that was switched power, key on, that was going to a 5V regulator on the board, there was also a red wire that was going to a 12v regulator but it wasn't getting any power. Jumped the terminals and the panel came to life, removed the jumper and it still works. It's a 97, so its pre CECU era electronics.
    The local dealership is refusing to supply any diagrams of any sort, and I can't find any online for the T2000 with an N14. I've thought of tracing and making my own diagrams, but that leaves a lot of room for error and I don't want to risk the electronics in this truck as the dealership charges a pretty penny.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
  4. SpeedyGonzalez
    123
    59
    Dec 28, 2017
  5. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Here you go.
    Juanelloco and SpeedyGonzalez Thank this.
  6. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Some more.
  7. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    More still
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    This should do it.
  9. SpeedyGonzalez
    123
    59
    Dec 28, 2017
    Holy crap lol, thank you so much. The truck looks like it's going to be parked for a month or two, state inspection turned up more issues than we thought it would and most of them are electrical.
    The interior is a cluster, but theres an issue with the dash power supply that kind of makes sense and might explain the dead short at the same time.
    Reverse light looks like its the reverse switch on the trans, I'm getting power on its feed and nothing out so that seems solved for now.
    I've been digging through the schematics and it appears I'm somehow getting 12 volts on the ground line both dashes and the line that should be supplying power is dead. Pretty weird considering the dash works perfectly.
    5UG and spsauerland Thank this.
  10. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    No
    No problem. Just remember on computer circuits you will see "ghost" voltage. The "ground" is a return switched in ECM that also has the ability to monitor circuit integrity. With a load the voltage will disappear on your multimeter.
    5UG, SpeedyGonzalez and 062 Thank this.
  11. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    A Temp gun may help narrow down which circuit. Just shoot your fuses and relays and any suspect harness.
    5UG, spsauerland and SpeedyGonzalez Thank this.
