Landing Gear Bending during loading
Discussion in 'Flatbed Trucking Forum' started by user232560, Jan 30, 2020.
  1. user232560
    user232560 Bobtail Member
    11
    9
    Jan 30, 2020
    Having some issues at a location I pull out of with the landing gear on my trailers bending during loading. The trailers are brought into place with a yard truck, and dropped to be loaded. Aluminum Flatbed trailers. From what I can conclude, it looks like when weight is put on the trailers, the bow in the trailer begins to flatten out and since the legs of the landing gear aren't able to go anywhere, and the brakes are locked, it is bending the landing gear back. Happens on all of our trailers, and we're at a loss. I would assume there's supposed to be a support jack under the front of the trailer when they're loading to prevent this if it isn't coupled to a tractor? Air suspension dumps when Parking Brake is applied.
    Reason for edit: Kept Getting the same question.
  3. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    Yes.
    user232560 Thanks this.
  4. jamespmack
    216,477
    Sounds like USG plant.
  5. Flat Earth Trucker
    4,313
    16,540
    Nov 19, 2018
    You may need to have a yard dog back under that trailer so it can be lifted and set back down with the landing gear straight.
    It can be difficult or impossible to crank up landing gear that is bowed outward as you have described.
  6. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    I’ll bet their air ride and as their being loaded it will squat the back of the trailer because there’s not enough air in the tank to keep it fully elevated. bending your landing gear as the trailer is moving forward with the airbags are squatting!
    kylefitzy Thanks this.
  7. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    Dump your trailers before they start loading and that will fix your problem again that’s if it’s air ride!
  8. user232560
    11
    9
    Jan 30, 2020
    Our trailers dump when the brake is applied. Still happens.
    Deere hunter Thanks this.
  9. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Our flatbed have been being equipped with the the type A pads. I dont ever use our flats so Im not sure if they’re a good solution or not.
    daf105paccar and PE_T Thank this.
  10. beastr123
    beastr123 Road Train Member
    2,947
    24,180
    Jan 2, 2014
    Moose Jaw SK CAN
    It is your air ride.
    Your air ride does not have enough air to support the load and therefore the bags collapse. Then the suspension pushes forward because the brakes are on.
    The simple solution is to dump the suspension air when you spot the trailer and tell the yard truck jockey to not inflate it during yard moves.
    If the air is dropped before the legs are lowered and brakes set then you will keep the strain off the legs. The arch coming out during loading will put some strain on the legs but it will be comparatively minor.
    Bean Jr. and Swine hauler Thank this.
  11. user232560
    11
    9
    Jan 30, 2020
    Our suspension dumps as soon as the parking brake is applied. Still happens.
