last resort
Discussion in 'CB Radio Forum' started by JNaum, Jan 1, 2014.
  1. JNaum
    JNaum Light Load Member
    277
    43
    Aug 12, 2012
    Dyersburg, TN
    Hey yall...I have a 2012 pete 587. I want a better antenna for my truck. There are no places to put it on the mirrors. So I have 3 more tries. First one is putting my wilson 5k in the back where the airlines are. Second idea is just get a 101 inch whip and put it back by the air lines. Third I will have to accept the fact I can not put any other types od antennas on this truck. Here is a pic of what my wilson looks like in the back. Also will this work and have less 2swr? 20140101_180409.jpg
  3. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    Most trucks I see, if not on the mirrors, have it on the side of the sleeper via a side mount. As long as there's metal under the ant. and it's not obscured by the truck it will work. best bet is to check with an SWR meter to ensure you don't have over 2.
  4. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    It will work with some limitations. The cab and trailer both will block some signal. But it will be better than no antenna.
  5. JNaum
    277
    43
    Aug 12, 2012
    Dyersburg, TN
    My side antenna s are getting bout 1.5-1.7 I just want better swr lol
  6. stacks
    stacks Road Train Member
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    Are you a sidebander or just talk am
    JNaum Thanks this.
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    I to am at my witts end with all this...In a different post i mentioned i can hear skip from all over usa and canada..Drives me nuts i dont go further or rec more than a few miles..I got a new stryker fresh tested coax and a grounded predator 10k on a volvo mirror mount...There is something im missing and cant figure it out..lol as good as a rep the mfj259b has i freakin swear its made more probs.......I guess its to much info and not enuf brain....
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If your hearing skip, but can't get your name called in DX land..."Buy a Amp"...something as small as a two-pill doing just a couple hundred watts is all you need...Either that, or get a Base set-up at the Home-20 and stick ya a flat-side beam up in the air 30-40'...
  9. Ridgeline
    22,717
    122,858
    What's tested coax?
  10. stacks
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    You don't need an Amp brother if skips rolling you can be heard on radio power I've just recently returned from the states' I ran a barefoot rci 2950 dx Wilson 1000 mag mount I was in the mountain states mostly Colorado' Wyoming 'Montana 'Idaho 'Utah' I spoke most days Eastern USA mid west Eastern Canada most people thought I was in a base you don't need an Amp really 👍
  11. stacks
    1,546
    850
    Oct 27, 2011
    Emerald Isle
    Btw that sounds like an awesome setup you have there I really like those predator 10 k Antennas I really hope you get your setup sorted out'...... I know that feeling only to well ......try googling reputable radio and get in touch with them after spending dollars like that it would be nice to be able to get a long distance copy........
