Leaking Roof
Discussion in 'Ask An Owner Operator' started by Phoenix Heavy Haul, Jan 26, 2023.
  1. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    Aight so my truck is an 18 Freightshaker 122SD mid roof. I’ve had leaks on each corner of my windshield and in my B pillar since I bought it. I used some silicone and went around areas of the windshield and around the seem where the top of the sleeper meet the roof mainly behind the stacks as I figured the seal was dried out due to heat.
    However it stil leaks every time it rains. And Freightliner engineers thought it would be amazing to mount an electrical box (PND) inside the B pillar. We’ll every time it rains I have to open up the access door and get the box out of the way or once it gets wet the truck will not shut off with the key or will randomly shut off just…depends on it’s mood.
    Yesterday I went to the streaking beacon and otw out they were rinsing my roof and it sounded like a river inside my roof.
    Has anyone ever experienced this and or know where to look to fix it??
    Siinman and D.Tibbitt Thank this.
  3. Ridgeline
    22,723
    123,039
    It is a known problem, you need to have a glass shop remove and reinstall the windshield with proper sealant.
    The sleeper gasket (that's what it is called) is another issue if it is not installed properly or in the case where the sleeper is mounted directly on chassis, will wear. If it needs to be replace, the sleeper has to be taken apart and the gasket is replaced from the inside.
    Siinman and Phoenix Heavy Haul Thank this.
  4. Phoenix Heavy Haul
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    But on the sleeper it’s not separate from the cab like on the Pete’s rather it’s like they put the top on separate with a thin gasket where it sits down onto the cab.
  5. IH9300SBA
    IH9300SBA Road Train Member
    2,427
    23,914
    Feb 26, 2021
    Cab light and air horn gaskets is another source of water intrusion.
  6. 201
    201 Road Train Member
    12,751
    26,227
    Apr 16, 2014
    high plains colorado
    Sounds like a job for Phil Swift,,I liked Billy Mays better.
  7. Phoenix Heavy Haul
    469
    1,398
    Feb 8, 2022
    Raleigh NC
    IH9300SBA, 201 and Siinman Thank this.
  8. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    I drove a mid roof Freightliner that leaked, but the leak was where the attached roof structure was attached to give the unit hi rise sleeper to complete the aerodynamic package.
    Phoenix Heavy Haul Thanks this.
  9. FLHT
    FLHT Road Train Member
    1,428
    2,541
    Aug 2, 2014
    It works !!!
    But if you screw it up it is NOT coming off.
    Silicone breaks down over time and is not as flexible over time.
    Polyurethane is what is used to glue in windshields these days.
  10. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Use some adhesive or silicone.
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Me too. You know he was snorting lines before every commercial take Lmao
