Learning the Super 10 this week
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pdizzle, Nov 28, 2011.
  1. pdizzle
    pdizzle Light Load Member
    95
    7
    Nov 20, 2011
    I've got the 13 speed down pretty good at my driving school. Later this week I'm taking out a Super 10 that a lot of the other students have been having problems with. I understand how the truck should be shifted but I hear that it is more unforgiven than a 13 or 18 speed. Any tips or pointers?
  3. Pappa Bear
    Pappa Bear Light Load Member
    105
    22
    Dec 20, 2010
    Springfield, OH
    Just remember to preselect your next gear. Most new guys wait until they are ready for the next gear to flip the button. The earlier you do it the better. I always liked the super 10, haven't seen one for a long time though.
  4. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    The only habit I had to break myself of when I had one, was slapping the shifter back and forth to be sure it was in neutral before starting the engine. With a super 10, that motion will make it go back and forth between ranges, like lifting the switch on a 13 speed.
  5. Hammer166
    7,600
    27,755
    Aug 18, 2007
    ~8600+' and loving it!
    The issue with the super 10 vs. the 13/18 is it takes longer to do the split shift as it's a larger gap between gears. Give it time to shift and you'll be fine.
    You'd never know it shifting it, but internally they're cousins. The 10 is missing two gears, and does the range shift automatically when the shifter moves to the far gate, but they are all structurally identical inside.
  6. LandShark
    LandShark Road Train Member
    1,525
    1,064
    Nov 22, 2008
    Riverdale, Ga
    if you can shift a 13 the super 10 should be NO problem
    just remember the super 10 is just the top half of the 13
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    My truck has the lightning 10 which is the electronically handicapped brother of the Super 10. Same principle but the lightning uses electric solenoids instead of air to make the split shifts. Works fine until it doesn't, lol!
  8. jeff1981
    jeff1981 Light Load Member
    55
    25
    Jan 11, 2009
    Pemaquid, ME
    Easiest way to drive it is to put it in first, then when you get ready for second flip the switch, take it out of gear, and put it right back in the 1st hole. It will be a lot smoother that way than selecting it and leaving it in the hole.
  9. pdizzle
    95
    7
    Nov 20, 2011
    i don't think my instructor would like me doing that lol.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    been using my super 10 for 12 years. never been touched, had clutch put in after 1.1 million miles. it is a convenient trans. to use, for me.
    TURKER Thanks this.
  11. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    I second that:biggrin_25519:
