Left and Right
Discussion in 'Trucks [ Eighteen Wheelers ]' started by emptypockets8125, Mar 13, 2010.
  1. emptypockets8125
    emptypockets8125 Bobtail Member
    28
    7
    Feb 20, 2010
    Waxhaw, NC
    I have a Frieightshaker and it is living up to its name! I need help where I should start. I have a centry and when I get up to about 50 mph the steering wheel will shake left and right until I get above about 60 mph. then it seem to settle down. some days are worst then others. I just bought the truck about 3 months ago and have not had the tires bal. yet. What do you all think?
  3. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    could also be tie-rod's.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Steering wheel shake at that speed range is always unbalanced/out of round steer tires. Unless the tires are brand new it is already too late for balancing. With the wheel shimmy you describe the tires will already be worn out of round. If you are lucky you just have a clump of mud stuck to the inside of one of the rims. If this shimmy has been going on for a while, you might have waited too long.
  5. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,185
    Aug 20, 2009
    Check the front end. I'd suggest tie-rods as mentioned earlier. At speed when it goes from left to right, does it go away when curve left or right?
  6. emptypockets8125
    28
    7
    Feb 20, 2010
    Waxhaw, NC
    When I am in a curve at that speed it will still do it. When I am on a off ramp my speed is lower the 50 mph so it does not do it! The tires only have about 5k on them.
  7. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    have your driveline checked (u joints,carrier bearing,rear end yokes)there you will find your issue.good luck.
  8. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Have that front end checked !!!!!
    While it may be a tie rod, it could be a host of many things.
    It's hard to "see" a worn pin.
    By continuing to drive it, you risk cupping your tires. Inviting even faster wear.
  9. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    At 50 mph? Yeah its your wheels. The fronts probably have self leveling compound. Problem with this stuff, if it sits at a dealer long enough it can get warm and drop to the wrong area. Take it too any tire shop. They will need to break the tire down. Ask if they can put the actual weights on it instead. Otherwise you can run fresh compound in it. Problem will resolve itself in 2 weeks of driving (maybe), but you will tear your rod ends out before then.
    If it were rod ends you would notice it in your pretrip with excessive wheel play. Plus rod ends would do it at any speed. The fact it does it even in turns points to out of balanced wheels. Flat spots would show up at 35 mph. If it were a worn pin, the way to check it is to jack that wheel off the ground, try to push the top of the wheel in and pull it out. A bad steering pin would move at that time, again tho, pin would be at any speed though.
    You might even ask the sales people if they would go good on a rebalance. Stuff like that doesnt cost them anything more than good PR.
  10. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    My truck does the same and my rite steer tire is allready showing wear. In my case King pins are loose but I dont have the green to fix it soon.
