Left the d**n switch on!!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MemphisOrion, Dec 12, 2024.
  1. MemphisOrion
    MemphisOrion Bobtail Member
    8
    7
    Nov 28, 2024
    Memphis TN
    Left the battery switch on (24 volt system) and now I get crickets when I turn the master switch to run. There use to be a series of clicks and beeps now nothing.
    Going to check the following:
    Batteries
    Starter Solenoid
    Any other suggestions?
  3. AModelCat
    164,498
    Yeah. What are we working on? Chevy pickup? Peterbilt? Marmon? White? Hayes?
  4. Star Rider
    Star Rider Road Train Member
    1,785
    18,468
    Sep 23, 2019
  5. broke down plumber
    4,058
    32,017
    Jan 25, 2024
    Dang man after you hit the switches on dat 6,4 you got to release drop her on da ground so she'll hop up on 3 as you roll thru da redlight .
    MemphisOrion Thanks this.
  6. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    If it dings its ok. If it buzzes you gots problems
  7. SomeCanadian
    SomeCanadian Light Load Member
    166
    481
    Nov 11, 2021
    Jump start box?
    If not you need one.
  8. Sirscrapntruckalot
    The switch to make sure it's off next time?
    I couldn't resist.
    Sirscrapntruckalot -
  9. MemphisOrion
    8
    7
    Nov 28, 2024
    Memphis TN
    Yea, I set myself up for the abuse…
    I have an Orion II with a 5.9 Cummins engine
  10. homeskillet
    homeskillet Road Train Member
    6,317
    48,882
    Jun 1, 2013
    Dayton, OH
    You need 24v to jump it.
    Those little Orions are a pain to work on.
    If the batteries are in a compartment under the driver's window, you should be able to hook a 24v jump pack to the big terminal near the 24v battery switch.
    Hook the negative to one of the front lug nuts.
    Turn both battery switches ON.
    Go inside the bus, close the driver's window, and try to start the bus.
    DO NOT reach in thru the window to hit the start button.....that places you MUCH TOO CLOSE to the batteries if something goes horribly wrong.
    If it's the Orion II/III with the batteries under the floor, you're on your own.
    If you don't have a 24v jump pack, hook two 12v packs together in series.
  11. MemphisOrion
    8
    7
    Nov 28, 2024
    Memphis TN
    Thanks for the response…I found out what happened…I tripped the ignition circuit breaker when I tried to start it…batteries were weak
