Lense Cap Marker Light Missing
Discussion in 'Experienced Truckers' Advice' started by MercySakesAlive, Feb 26, 2026.
  1. MercySakesAlive
    MercySakesAlive Light Load Member
    132
    74
    Aug 8, 2008
    seattle ,wa
    Picked up a rental tractor trailer. 1 of 4 lense caps on markers on tractor roof is missing. Light works... is this going to be a problem? In this scenario i am not going to replace the lense.
  3. Lennythedriver
    Lennythedriver Road Train Member
    2,411
    8,223
    Feb 14, 2020
    it have to be a really picky DOT officer, and you won’t get shut down. You’d probably get a “fix-it ticket” Report it to the rental company. Send them a picture as well.
    The bulb inside is usually just a clear white bulb. The plastic lens cover is tinted amber. That tinted cover is what makes the light legally amber from the outside.
    So if the outer lens is completely missing and you are just seeing a white bulb glowing, then technically it is not compliant because front clearance lights must display amber.
    If the inner housing is still amber plastic and the light still shines amber, you are probably fine. I’ve seen actual amber bulbs.
    Lonesome and tscottme Thank this.
  4. Toomanybikes
    Toomanybikes Road Train Member
    2,486
    3,461
    Apr 8, 2009
    If lights don't glow amber where they are supposed to glow amber and red where they are supposed to glow red you are inviting an inspection.
    Other then that, if lights are glowing properly, they are on a limited lifespan with covers missing.
    Lennythedriver Thanks this.
  5. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Never leave the rental agency with missing parts, especially on a non-compliant piece of equipment. You’ll be charged for those lenses and you’re setting up yourself for being stopped. Pre-trip driver!
  6. MercySakesAlive
    132
    74
    Aug 8, 2008
    seattle ,wa
    They said they didn't have the part and it wasn't important. The whole vibe was "dont bother us with work."
    beastr123 Thanks this.
  7. buzzarddriver
    3,823
    11,528
    Feb 1, 2011
    Dallas, TX
    Get a orange magic marker and paint the bulbs.
  8. MercySakesAlive
    132
    74
    Aug 8, 2008
    seattle ,wa
    Bulbs are right color. Just no lense protection. I went back and said not good enough please fix.
    buzzarddriver Thanks this.
  9. Ridgeline
    22,720
    123,212
    not your job to replace it, but it begs the questions - did you do a pre-trip, and did you ask them to replace it?
  10. MercySakesAlive
    132
    74
    Aug 8, 2008
    seattle ,wa
    I asked them to. They said no. I came back later and complained. Theyre going to repair...
    Numb Thanks this.
  11. Moosetek13
    Moosetek13 Road Train Member
    14,977
    19,014
    Nov 1, 2010
    Burnsville, MN
    Maybe someone will correct me but, I don't really see a problem if the cover is missing but the bulb is working and displaying the correct color.
