Lift axle
Discussion in 'Flatbed Trucking Forum' started by whiskeyone, Apr 29, 2016.
  1. whiskeyone
    whiskeyone Bobtail Member
    13
    Feb 20, 2014
    ohio
    Spec-ing new flatbed, what's pros and cons of front lift axle. Lot's of knowledge on this site hoping to tap into some of it. Thank you
    Dominick253 Thanks this.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Im interested too.
  4. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Looks cool and saves tires and fuel
  5. SAdriver
    SAdriver Light Load Member
    158
    348
    Feb 11, 2016
    San Antonio, TX
    Pro
    - Saves tire wear when turning while up.
    - Saves fuel
    - Watching the axle go up and tire spinning freely after takeoff because is air actuated (easily amused)
    - Saves money on toll roads
    Con
    - Changes backing dynamic when up
    - Changes turning dynamic when up
    - Usage has a ceiling based on weight
    - Aggravating when broken knowing light load mpg is going to #### because of it
  6. TripleSix
    133,268
    If you're going to life an axle, lift the rear axle instead. Makes for a more merge maneuverable trailer.
    peterbilt_2005 Thanks this.
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    @whiskeyone
    Spreadaxle?
    OTR or regionale runs?
    Budget for extra's is .....$?
  8. Roberts450
    2,237
    3,638
    Feb 6, 2016
    I do know there are some guys up here in the northwest that run 53' flats with 2 rear steer lift axles. SAdriver made me remember it when he mentioned the changing turning points and I do believe those trailers are set up that way because of the off track law that Idaho has. For running the majority of US95 they have a max of 5.5' off track. From what I remember ID dosent count the lifts when calculating the off track. So it lets them spec a truck and trailer long enough for max gvw and to meet the off track law.
  9. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    The only con is if you forget to put it down after loading heavy. It will be a very expensive mistake.
  10. Roberts450
    2,237
    3,638
    Feb 6, 2016
    We have a couple 4 axle chemical tankers that have auto down front lifts. It works off of air pressure in the tandems bags and once unloaded you push the vavle in to lift it.
  11. spyder7723
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    For a company that would be a good idea keep idiot employees from burning axles up. But for a guy that owns 1 it's not worth the extra expense nor extra maintenance headaches. The more complicated you make a system, the more expensive it becomes to keep it working over the servicable lifetime of the trailer.
