Lights
Discussion in 'Kenworth Forum' started by Mason Allen, Aug 1, 2020.
  1. Mason Allen
    Mason Allen Bobtail Member
    8
    Aug 1, 2020
    I’m looking to buy a 2007 W900L and the only lights working are the headlights and chicken lights under the drivers door. No brake lights, no rear turn signals or tail lights and no clearance lights. Has anyone had this issue. The truck has a Cat C-15 accert if that helps
  3. AModelCat
    164,177
    I'd tell the seller to fix all that stuff if they want to sell it.
    HoneyBadger67, spsauerland and Cat sdp Thank this.
  4. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    The earlier models had problems with corrosion on the back side of the fuse panel.
    spsauerland Thanks this.
  5. Mason Allen
    8
    Aug 1, 2020
    Thanks I’ll take a look at it. Is it the fuse panel under the dash?
  6. Mason Allen
    8
    Aug 1, 2020
    I talked them down so cheap, they won’t do anything to that truck.
    HoneyBadger67 Thanks this.
  7. 062
    6,321
    33,958
    Oct 20, 2013
    Yes, I think it was so common that the dealers stock the fuse panel. @spsauerland @Goodysnap
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Do you have and able to use multimeter? If so, post last six of VIN and I will get exterior lighting wiring diagram.
    062 Thanks this.
  9. Mason Allen
    8
    Aug 1, 2020
    My mechanic does and I can get you the vin number tomorrow. Thank you for your help.
  10. Mason Allen
    8
    Aug 1, 2020
    157067 is the last 6 of the VIN
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Here you go, enjoy. P94-1588 Headlights, P94-1590 Park and Tail, P94-1591 Marker/Clearance, and P94-1594 Turn and Stop Lights.
    062 and QUALITYTRUCK Thank this.
