Lipe vs. Easypedal
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allan5oh, Apr 18, 2014.
  1. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    What do you folks recommend and where to buy? Use is a 12.7 detroit around 550 hp tuned by Leon, probably putting out around 1800 tq if not a bit more. I'm usually under 90k gross. Also does anyone have any experience with this style clutch fork?
    http://www.fleettruckparts.com/Clutches/Clutch-Release-Roller-Fork
    Looks interesting.
  3. bgxpress2006
    bgxpress2006 Light Load Member
    248
    73
    May 25, 2013
    Montreal, Quebec
    Go with the Lipe, you wont have to worry about a spring coming undone
    allan5oh Thanks this.
  4. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Looks like I could get away with the "lipe 2" which is rated for 2000 ft lbs.
  5. rollin coal
    rollin coal Road Train Member
    13,589
    27,946
    Mar 29, 2008
    TN
    A mechanic was telling me about a Sachs easy pedal they'd put in a lot of equipment and had been good clutches. I thought there were a few guys on here not happy with Lipe going back with Eaton.
    Cat sdp Thanks this.
  6. kwswan
    kwswan Road Train Member
    2,023
    11,029
    Jul 26, 2009
    mcminnville,tn.
    I just had a easy pedal rated for 2000# put in last week & so far I like it.
  7. bgxpress2006
    248
    73
    May 25, 2013
    Montreal, Quebec
    what you like about the easy pedal is the ease at which to push the clutch in, they feel great but are prone to springs breaking, Lipe has a different design which is not prone to failure, yes the pedal feels heavier, id rather have a heavy pedal then having to replace a clutch prematurely due to a broken spring... your choice!!!
  8. slippez
    slippez Bobtail Member
    22
    4
    Apr 13, 2014
    that clutch fork is used on eaton solo clutches. have to change it when going to easy pedal.
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Mid America Clutch. Built in the Easy Pedal style.
