I used to be in the habit of taking my load locks out of the trailer when getting loaded or unloaded. I would usually just lean them up outside against the building then put them back in after getting loaded/unloaded. It seems like it used to be common for the loaders to keep the load locks, and it taking an extra 10-15 minutes or longer, to bang on the dock door or have to go through the inside to get them back. It seems like this used to happen a lot so I got in the habit of taking them out.
But here recently I've had two load locks come back mysteriously broken, once when it wasn't even being used.
So I'll probably get in the habit of taking them out again.
Load lock swap
Discussion in 'Shippers & Receivers - Good or Bad' started by CommDriver, Apr 3, 2013.
I learned, they come out before the dock get's bumped. Coke A Cola in Arizona will take them and they go into never never land.
had a driver run over a brand new load lock with the forlift, bent it and then deny it.. I agree with aiwiron, they come out before the dock get bumped
aiwiron Thanks this. -
But it was your fault for giving him the load lock, just kidding.
I use straps, never liked the load locks.
but, yeah, I remove them before the dock is bumped so they don't walk away.aiwiron Thanks this. -
This deal is kind of iffy if you are accused of the load being damaged you have no out as to when you removed the load locks or straps, I never remove either one before the load is inspected for damage. I just heard this a while ago and have always kept it in the back of my memory. Be Safe Drivers.
NavigatorWife Thanks this. -
I do multiple drop and I try to take them out after I talk to the first receiver, it doesn't always happen, and I make sure I get them back, or they probably would disappear.
I have seen damaged ones but haven't had much trouble, I carry collapsibles just in case, but the others are available in the shop, so far;.starsonwindow Thanks this. -
I had a refrigerated trailer once that I hauled multi-drop stuff on, needed several load locks to secure the product. Got tired of losing them , so I ran a small cable from the nose of the trailer, bolted near the top, to the rear of the trailer. I then used another cable to secure the locks to that cable, so the locks could be slid wherever I needed them. Took about an hour to do, ended my load lock vanishing problem.
You should patent and sell that system , seriously .
