Load Securement / Rubrails
Discussion in 'Experienced Truckers' Advice' started by Powder Joints, Nov 11, 2025.
  1. Powder Joints
    7,982
    8,383
    Sep 25, 2007
    Rosamond, SoCal
    Is it legal to attach your straps to the rubrail instead of the frame, or looping your chain around the post pocket and hooking it back to the chain. seems like the the chain connecting to the chain would be stronger.
    D.Tibbitt Thanks this.
  3. Diesel Dave
    9,613
    32,330
    Jan 20, 2010
    Hesperia, Ca.
    I’ve done both, wrap around the pocket or spool, and rehook to chain link or wrap around pocket and hook on pocket end(like a u). Both are legal. Usually when I hook back to link, you can use that style for 1/2 links to adjust if the binder is to loose or tight to snap(secure).
    Oxbow, 4mer trucker, D.Tibbitt and 2 others Thank this.
  4. Razororange
    Razororange Road Train Member
    2,709
    25,770
    Dec 20, 2011
    Milwaukee, WI
  5. Diesel Dave
    9,613
    32,330
    Jan 20, 2010
    Hesperia, Ca.
    IMG_8060.jpeg Here are both styles
    MACK E-6, Oxbow, 4mer trucker and 4 others Thank this.
  6. MacLean
    MacLean Road Train Member
    1,380
    4,090
    Sep 12, 2017
    The trailer is always the weakest link compared to the chain. Most times there’s a sticker on the trailer showing what it’s good for. When it doubt go with 6000 lbs.
    Bean Jr. and gentleroger Thank this.
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,677
    24,352
    Dec 15, 2007
    Northern Indiana
    A guy told me years ago, a cop in Commiefornia gave him a hard time, about attaching straps to the rub rail. The cop said they need to be behind the rail, and attached to the underside of the deck.
    gentleroger Thanks this.
  8. D.Tibbitt
    156,822
    Be very careful when running chain around rub rail spools. It is legal yes BUT not all trailer manufacturers weld the spools all the way around and you can pop them out fairly easily... The last company i was with guys would cinch down on 1 spool with a coil and just about every spool was popped out because of that... Its better to secure to a stake pocket and a spool together. Or 2 spools if thats the only option.
  9. Diesel Dave
    9,613
    32,330
    Jan 20, 2010
    Hesperia, Ca.
    Done that too… depends the condition on the pockets or spool.
  10. TripleSix
    133,196
    Translation: CommieCop has his preferences but is not familiar with 393.100.
    OldeSkool, MACK E-6, Bean Jr. and 4 others Thank this.
  11. Powder Joints
    7,982
    8,383
    Sep 25, 2007
    Rosamond, SoCal
    Qutoe off FMCSA website,
    Cargo Securement Rules
    Proper Use of Tiedowns
    The new regulations require each tiedown to be attached and secured in a manner that prevents it from becoming loose, unfastening, opening or releasing while the vehicle is in transit. All tiedowns and other components of a cargo securement system used to secure loads on a trailer equipped with rub rails must be located inboard of the rub rails whenever practicable.
    This would indicate that its is at least highly reccomended to only attach to rubrails when there is no other choice.
    So its probably not illegal, it maybe rated lower than the spool/steak method. Any how just trying to clarify as my self I have attach to rubrail when securing loads, but generally perfer to attach to the frame or loop back around the spool and pocket back to the chain, I think personalluy I perfer linking back to the chain.
    Lonesome Thanks this.
