Loading a reefer on a lowboy
Discussion in 'Experienced Truckers' Advice' started by Ikold, Sep 9, 2020.
  1. Ikold
    Ikold Bobtail Member
    8
    13
    Sep 6, 2020
    Recently purchased a reefer and a lowboy at auction. They are both near one another. Would it possible to load the reefer on the lowboy or would I be to tall going down the road. Need to get from GA to CO.
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    reefer by itself is 13'4 - 13'6 depending on 5th wheel height. Add 18" for the trailer you're loading it on....
    MACK E-6 and Kyle G. Thank this.
  4. Diesel Junkie
    Diesel Junkie Bobtail Member
    19
    14
    Oct 10, 2015
    Almost all reefers are right at legal height, so I would say no.
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I wouldn't try it, seems like a good way to lose a trailer roof. You'd end up at nearly 16 foot tall, not to mention getting a 53 foot reefer in the well of a lowboy could be interesting.
    Canadianhauler21, Kyle G. and pavrom Thank this.
  6. Cat sdp
    Cat sdp . .
    21,287
    76,073
    Apr 8, 2012
    Orion's Belt
    Power only haulers will move it for cheap........
    Brettj3876 Thanks this.
  7. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    He could haul it.
    But permits and escorts amd routing won't be cheap.
  8. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Take the wheels off.
    The reefer, not the lowboy... in case there is any confusion.
    Or maybe just let the air out, block it, yadda, yadda, yadda...
    Assuming the lowboy is big enough to handle the reefer, otherwise find a power-only tractor as suggested, find a one-way load, etc.
    Might have to remove the landing gear too. If there's a will, there's a way. Just whichever makes the most sense.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Just flop it over on its side:D
  10. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    So have SWIFT load it?
    MACK E-6, Dino soar, okiedokie and 2 others Thank this.
  11. nikmirbre
    nikmirbre Road Train Member
    5,584
    10,335
    Jul 27, 2011
    High Point NC
    Most lowboys with an 18inch deck height would probably be 15ft high loaded. It depends on where the from and to locations are. Ga and Tn and SC no problems permitting that high. But I’m sure it’d be cheaper having power only companies haul them.....
    062 and Wasted Thyme Thank this.
