Logging Duty Status
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by M-B, Apr 29, 2019.
  1. M-B
    M-B Bobtail Member
    This should be simple, but getting the answer is a mess:
    Through the week I will drive over the road, regional, and possibly a day of local. OTR and Regional are simple - Fire up the ELD, log my day, and live. However, when I have time left at the end of the week and want to make a few bucks, I will hop in a company van (same company I drive for the rest of the week), 9,000GVW, and make local deliveries. Issue is that the vans are utilized by non CDL employees, and do not have ELD in them.
    With my mix of work, am legal logging these days as strictly on duty?
    If you don't know the answer, I will gladly accept a contact that can answer. FMCSA is impossible to get through to, and I have three different answers from DOT inspectors at weigh stations.
  3. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,356
    Nov 1, 2017
    The Sticks, Idaho
    If it were me... Non cdl work never happened.:rolleyes:
    DenBob and not4hire Thank this.
  4. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    It would seem they are not commercial motor vehicles, assuming they do not fit the following definition:
    Commercial motor vehicle means any self-propelled or towed motor vehicle used on a highway in interstate commerce to transport passengers or property when the vehicle—
    (1) Has a gross vehicle weight rating or gross combination weight rating, or gross vehicle weight or gross combination weight, of 4,536 kg (10,001 pounds) or more, whichever is greater; or
    (2) Is designed or used to transport more than 8 passengers (including the driver) for compensation; or
    (3) Is designed or used to transport more than 15 passengers, including the driver, and is not used to transport passengers for compensation; or
    (4) Is used in transporting material found by the Secretary of Transportation to be hazardous under 49 U.S.C. 5103 and transported in a quantity requiring placarding under regulations prescribed by the Secretary under 49 CFR, subtitle B, chapter I, subchapter C.
    - eCFR — Code of Federal Regulations
    Therefore, your non-CMV driving is considered on-duty, but not driving:
    Driving time means all time spent at the driving controls of a commercial motor vehicle in operation.
    On-duty time means all time from the time a driver begins to work or is required to be in readiness to work until the time the driver is relieved from work and all responsibility for performing work. On-duty time shall include:
    (8) Performing any other work in the capacity, employ, or service of, a motor carrier;
    M-B and Cattleman84 Thank this.
  5. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    I would think anytime running the van, and getting paid for it, you or your company must log you as on duty on your ELD.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    If it is OTR Regional or big truck, It's ELD, logbook if necessary etc.
    IF IT IS NOT CDL VEHICLE, NO ELD etc then it's your timeclock in the place you say good morning boss after clocking in that determines your work time.
  7. illini50
    illini50 Bobtail Member
    8
    Apr 29, 2019
    i hate elds
    M-B Thanks this.
  8. Powder Joints
    7,980
    8,378
    Sep 25, 2007
    Rosamond, SoCal
    Legally your delivering and or picking up items for the company. Your at a minimum on duty, but I believe legally you should be logging it as driving when drining, on duty while loading or unloading.
    This is not necessarily how I would log it. But that was not the question.
  9. OT John
    OT John Bobtail Member
    17
    7
    May 6, 2019
    If you are working, even a non CDL vehicle, it is On-Duty time, assuming you are running under logbook exempt (unless) status. Do yourself a favor and log it that way. If some crazy stuff happens and they audit you....it could go very bad if you try and hide it.
