Logging Pretrip
Discussion in 'Trucking Industry Regulations' started by strat24, Feb 19, 2010.
  1. strat24
    strat24 Light Load Member
    283
    166
    Oct 11, 2009
    Illinois
    How long do you log your pretrip?
  3. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
  4. crazyhorse00
    crazyhorse00 Light Load Member
    101
    19
    Aug 20, 2009
    Butler Mo
  5. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    How long do you spend doing it?
    Depends on carrier how long you spend on the pre trip
    Now remember with all this 2010 stuff comming out you really need to do a complete pre trip or post trip to make sure your truck is ready/safe to drive. You alone are responsiable for the trucks safety.
    I run team now, but when I was solo I wanted to do a complete post trip before I went to sleeper making sure I had time to get any problems fixed overnight.
    Then in the morning I would flag a pre trip.
    creepailya Thanks this.
  6. Kabar
    Kabar Road Train Member
    1,041
    395
    Nov 5, 2008
    Pell City Al
    You are required to do an inspection every day. It can be done pre-trip, post-trip or in-between. I do mine pre-trip unless I will be fueling latter in the day and then I will do it then.
  7. RickG
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    You are required to do a pretrip before operating a vehicle . Part of the pretrip is reviewing the DVIR that was filled on as part of the previous post trips . Written DVIR's are required at the end of every trip . Nothing is required to be written as part of the pretrip unless there is no DVIR to check . Then a new DVIR must be filled out during the pretrip .
    http://www.fmcsa.dot.gov/Spanish/Part396_index.htm
    Canadian regulation requires written inspection within 24 hours but it can be post trip or pretrip .
    otherhalftw, creepailya and Baack Thank this.
  8. outerspacehillbilly
    outerspacehillbilly "Instigator of the Legend"
    4,349
    2,430
    May 28, 2009
    The Who's Your State
    We give up how long? :biggrin_25523:
    FriedTater Thanks this.
  9. DIESEL DOG
    DIESEL DOG Light Load Member
    56
    29
    Nov 15, 2009
    Truck'n/MotorCoach'n
    We run electronic logs and I show minimun of 10 minutes on duty for both pre and post trip
  10. Swaps
    Swaps Heavy Load Member
    757
    361
    Jan 10, 2010
    Minnesota
    my instructor says that the minimum is 15 minutes... because the paper log book is broken down in 15 minute increments.
    A good pre-trip should take a person at LEAST 15 minutes to perform.
    A question I have for the veteran drivers, what things were you instructed to do, but skip? Do you do all the brake checks? do you pump the air pressure down so the spring brakes pop on? Do you test the spring brakes, and trailer brakes and service brakes EVERY day when you start out?
  11. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I have rarely seen this done. Most of the time I got a warning from the companies that this caused undo wear on the airbags.
    You will know if something is up when you start up your truck and the alarm goes off for low air. Or if it suddenly goes down. A pin hole in the trailer red line was all it took for me to loose air pressure in less than 2 minutes.
    As to the log, 15 mins you have to be flying around the truck to get all the inspections done. 15 is about what I get for mid day pretrips, yet to do a propper one 30-45 minutes. No point to rushing safety.
