Looking for.....
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Commuter69, Mar 19, 2021.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    A part number for the correct RIGHT headlight assembly for a 2019 Cascadia. I took a rock and the lens broke. Even though the lights work, I am going to assume that it's not replaceable without replacing the whole thing. Please correct me if I am wrong. A video that guides me through the physical replacement would be helpful too.
  3. 062
    062 Road Train Member
    6,299
    33,853
    Oct 20, 2013
    RocketyMan Thanks this.
  4. Commuter69
    1,142
    635
    Jul 2, 2014
    What difference does this make? Just curious.
  5. 062
    6,299
    33,853
    Oct 20, 2013
    That’s how dealers look up part numbers except international they need 8.
    BoxCarKidd Thanks this.
  6. 062
    6,299
    33,853
    Oct 20, 2013
    You can just call Freightliner with the last 6. Some will give you a part number some won’t.
  7. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    A66-01405-002 is RH/ A66-01405-003 is LH.
    spsauerland, black_dog106, 062 and 2 others Thank this.
  8. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    Because it depends on the unit's configuration, parameters, wiring, etc. Some trucks might have LED, some HALOGEN. Not necessarily all plug 'n' play.
    QUALITYTRUCK and 062 Thank this.
  9. Commuter69
    1,142
    635
    Jul 2, 2014
    KD3320
  10. RocketyMan
    549
    337
    Jun 5, 2015
    Yours is in fact the LED headlamp. for RH it is A66-01405-003 that was mentioned earlier.
    The ULB and DRL module are still useful on the light if they were working. You can remove those with a torx. The ULB tho may be obsolete as per a SB 54-331. But I wouldn't worry about that necessarily if youre going to be ordering a whole new assembly.
    Removal should be easy (if you don't have a bull-bar). Open hood, disconnect connector without breaking it, remove all 4 fasteners paying attention not let the housing to fall (maybe leave one fastener in loosened), close hood, and shimmy out old one. Be strategic.
  11. Commuter69
    1,142
    635
    Jul 2, 2014
    Does anyone know of an online source for a used part that survived a crash, when the truck didn't?
