Looking to get a GOOD CB setup
Discussion in 'CB Radio Forum' started by Cattleman84, Nov 14, 2017.
  1. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    I'm want ing to get a good quality CB setup in my truck, some thing that receives and transmits well... And I want it to have a really good range. What is good now days?... I have an old cobra 29 with an analog signal gauge and all controls are switches and dials... Would it be worth setting up and how can I boost its range if it is worth my time.... Also I need a new Mic if I use this old cobra, what should I get?
  3. shogun
    shogun Road Train Member
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    You could convert that radio to a mosfet final and get good output power from it. As far as microphones go, the astatic 636L is a good quality noise cancelling microphone. As far as antennas go, the critical part is proper grounding. A wilson silver load fiberglass, a skip shooter fiberglass, or a predator 10k dual coil antenna would all be good choices. To increase range anymore would necessitate an amplifier, butthe problem is most people run junk setups and can't hear you past one mile.
    So, get the radio peak and tuned or mosfet converted, get a good antenna and ground it.
  4. weasel
    weasel Light Load Member
    111
    55
    Dec 30, 2006
    I'm using a cobra 29 LTD Taiwan model, 40 channel with a SRA 198 mic..got a decent antenna setup, 5.5 Francis mounted high and swr are good...good range with my setup...Others are telling me audio loud and clear....just a stock radio that's had modulation set and an alignment...
  5. Cattleman84
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    So I did a little research on the radio I got... It is a vintage cobra 29 23 channel... Ya know the one that made cobra 29s famous back in the day. I hooked it up today and it receives but I'm not sure if it transmits... I threw a cheap Mic on it but couldn't get anyone to give me a radio check, but I could hear a couple guys though. I think I'm going get it repaired (if I can) and keep it around as a conversation piece and maybe a backup.
    Until I can get a better one of my own my father in law is giving one of his radios, he just retired after almost 30 years on the road in a truck. I was looking at a few online and was wondering if getting one that is SSB capable is worth it? Also anyone know anything about the Galaxy DX939?
  6. shogun
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    SSB is rarely used by truck drivers, usually base stations in the upper channels. For that Galaxy 939 money, you should just buy a used Cobra 25 or 29 or a comparable uniden and get a good antenna and coax. If you aren't familiar on how to set and check SWR's, a good cb shop can do it. Then later on down the road you can get an amp if you want to talk further.
    weasel Thanks this.
  7. weasel
    111
    55
    Dec 30, 2006
    A 23 chànnel cobra 29 is vintage, say 50 yrs old..problem there is internal components tend to dry up and get brittle. Not saying it is but possible with age.
    rabbiporkchop Thanks this.
  8. Cattleman84
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    So I picked up a radio from my father in law tonight... A Cobra 148 GTL... And it is in good working condition he was using it as recently as 2 months ago. Anyone ever run one of these... If it is as good a radio as he says I may just bag getting another for awhile.
  9. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    The older 148's are excellent radios good audio, excellent receive and very stable on SSB if you want to use that mode during periods of skip. The newer ones made in China with front mounted mic connector have a reputation of being average but I have one and have never had a problem with it. The one thing I like most about the 148 is the white noise/ static level, it seems to be very low almost nonexistant even in these new trucks that have E-Logs, cameras,and other electronics that can generate annoying static and interference.
    Cattleman84 Thanks this.
  10. Cattleman84
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    Yea the one I have is an older one with the side mount Mic. Thanks for the info... I'm going to install it tomorrow and give it a whirl.
