Loosing 30 PSI
Discussion in 'Questions From New Drivers' started by Gustavic, Aug 14, 2024.
  1. Gustavic
    Gustavic Bobtail Member
    Aug 14, 2024
    Is loosing 30 off your air gauge a good enough reason to shut your truck down it kept the air at 120 but as soon as I turned the truck off well with in 5 minutes I lost 30
    77fib77 Thanks this.
  3. TurkeyCreekJackJohnson
    TurkeyCreekJackJohnson Medium Load Member
    533
    1,514
    Feb 7, 2024
    South Western US
    Definitely will not pass an inspection.
  4. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Yes. If you own the truck, get a spray bottle with soap and water. Spray all the air hoses and airbags, the leak should not be hard to find.
  5. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    Might even just use your ears.
  6. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,548
    2,702
    Jan 7, 2023
    As long as you can maintain at least 90 psi while running, you shouldn't have a problem getting to your destination. Was that leak-down with both the red and yellow valves closed?
    Oxbow Thanks this.
  7. 77fib77
    77fib77 Road Train Member
    11,639
    76,731
    Jul 7, 2010
    St Louis
    That's too much. Where does it sound like it's coming from? Is it only when red and yellow valves are pressed in?
