Losing Air
Discussion in 'Trucks [ Eighteen Wheelers ]' started by topcat1974, Dec 12, 2013.
  1. topcat1974
    topcat1974 Light Load Member
    119
    31
    Sep 12, 2010
    Charlotte, NC
    Can u guys help me out ASAP. I know a guy that is having problems. As he is sitting still his air gauges reaches 120 mark and releases air, then he will release his breaks and begin to roll down the road, at this time his gauges go to about 55-60 range and the low air waring comes on. But as soon as he puts his foot on the break peddle the gauges go back to about 80 psi but never 120 until he is sitting still again. Can you guys give me any ideas what this can be please
    h50 Thanks this.
  3. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    It could be leaking parking brake can.. Get out and listen..
  4. KC Guardrail
    KC Guardrail Light Load Member
    199
    155
    Dec 7, 2013
    It's hard to hear an air leak over the Internet.
    Cetane+ and Heavyd Thank this.
  5. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    Is this with trailer attached or bobtail?
    Has he done the air brake leakdown test?
    Has he chocked the wheels, engine off, released the brakes, and listened, looked for a air leak? If leak is not internal of a part, windex works well if you can't find the source of the sound. Spray windex at sound and your leak should become visable.
    From your description, he should have put himself OOS, so probably going to a repair facility would be best.
  6. BuzzardTrkr
    BuzzardTrkr Bobtail Member
    20
    9
    Nov 19, 2013
    Dallas, TX
    My air leak is coming from the black cap in the photo (the nice clean black thing in the midst of the dirt). Little research on air diagrams and it's labeled as governor.. Starts leaking at 50 PSI, and when trailer is supplied it will only build pressure to 65-70 psi and then sits.. You can hear air passing through the trailer supply valve in the cab... Can I adjust or do I sit and wait for repair guy? Road rescue wanted me to drive to Petro 30 miles down the road, but where the leak is I can't imagine the brakes are fully releasing or operating well if, at all. They are "sending someone". But if I can go to them I'd be slightly happier. Yesterday, it seemed ok and built pressure fine, but towards the end of the trip (last 100 miles or so) it felt the load got heavier and my MPG dropped 2 mpg down to a 6. At first, I attributed it to the mountains I was pulling, but now I am not so sure.. I normally stay pretty high.
  7. BuzzardTrkr
    20
    9
    Nov 19, 2013
    Dallas, TX
  8. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Seems like it's freezing.
  9. Hammer166
    7,601
    27,763
    Aug 18, 2007
    ~8600+' and loving it!
    That's the quick release relay for your park brakes. It should only discharge air when the park brake is initially set.
  10. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Dump a bottle of dry gas or air line antifreeze into your trailer supply line. If its freezing that will solve it, if not, you need a new valve.
