Losing nuts
Discussion in 'Flatbed Trucking Forum' started by JasperGB, Mar 2, 2026 at 5:15 PM.
  1. JasperGB
    JasperGB Bobtail Member
    26
    48
    Jan 26, 2025
    New Xtreme Step Trailer.
    Nut on cage bolt vibrated loose.
    Lucky low speed lockup.
    Heads up for all: Check your nuts.
    Special thanks to the trucker who provided a spare so I could cage the bugger.
    And new item added to spares to carry.
    D.Tibbitt Thanks this.
  3. Big Road Skateboard
    7,025
    39,747
    May 2, 2021
    The nut on the cage bolt vibrating loose caused your lockup?
    D.Tibbitt and Bean Jr. Thank this.
  4. D.Tibbitt
    156,361
    If u have to drive around with caged chambers u might wanna get it fixed ?? :eek: not sure what else u would mean
  5. JasperGB
    26
    48
    Jan 26, 2025
    Post Hoc Ergo Propter Hoc
    Waiting to examine brake chamber after removal.
    New trailer less than 10k miles.
    Perhaps if Quality Control missed this, they missed something else.
  6. Boardhauler
    Boardhauler Road Train Member
    1,734
    3,681
    Dec 21, 2008
    Ballin' in it for Shakey
  7. beastr123
    beastr123 Road Train Member
    2,942
    24,140
    Jan 2, 2014
    Moose Jaw SK CAN
    One of the first things I did when I bought or was assigned a company trailer is to remove the caging bolts from their holders and put them in my tool box. They lay in the bottom of the little red tool box along with the hammers and wrench roll.
    I found that winter salt spray will seize them in the holders after one season and after a second season you MAY be able to remove the nut but the chances of moving the bolt are very small, even with a 3lb hammer.
