Losing power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Westgaform, Nov 24, 2018.
  1. Westgaform
    Westgaform Bobtail Member
    4
    I have 1994 white/gmc with a n14 it runs great has been pulling fine only 357000 miles but having to gear down to pull hills just don’t have the power it had started all of a sudden Any body got any suggestions ? Changed fuel filter no water air filter is new
  3. xsetra
    xsetra Road Train Member
    5,195
    7,145
    Aug 21, 2011
    Injectors getting old.
    Leak in the air supply.
    Check the filter in the body of the fuel pump.
    Fuel lines collapsing internally.
    Air getting in fuel lines.
    Cooling plate behind ecm has a hole.
    Something fell in fuel tank plugging fuel outlet.
    How does motor sound with no power.
    Does run rough or smooth?
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I would check for air leaks around the turbo fittings and do a pressure/leak test if you can.
    Westgaform Thanks this.
  5. Westgaform
    4
    Runs smooth.
  6. Westgaform
    4
    Thanks I’ll checked that too
  7. Westgaform
    4
    Didn’t find any leaks in intake hoses but after I changed fuel filter. No water found after driving with new filter seems to be fine for now Never saw this happen before be nice if that cured problem Was a Baldwin filter any one else had this before ?
  8. raferko
    raferko Bobtail Member
    22
    6
    Oct 23, 2018
    Japan
    I would do a pressure test on the cac, assuming there’s no misfires, injector trouble, etc....then go from there
  9. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Under 20 bucks for all the pvc and fittings at Home Depot to pressure test your vac and while system all the way to the block.
    Just undo the pipe from turbo to cac. Use cac boot and install pvc with your air fitting on it. No need to disconnect other side. Load it up to about 20 psi is all you need to find leaks. Don’t get crazy with psi while pressure testing. You will wind up exploding the pvc or shoot it out of boot.
    If it’s an old cac, I’ll bet you will find a ton of air leaks in it and maybe a cracked elbow or 2
    xsetra Thanks this.
  10. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Sounds like you might have gotten some bad fuel that plug up your filter
  11. Atlaw4u
    750
    1,131
    Jun 8, 2018
    Did you locate/solve your problem?
