Low air warning buzzer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by LMB, Dec 4, 2014.
  1. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    Where is the low air warning buzzer located on a 2009 volvo vnl670 ?
  3. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    Should be under the hood by all the air lines. I believe it's the yellow sensor. Red is for brake lights.
    LMB Thanks this.
  4. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    No. Its a part of instruments cluster. Can be repaired, but if you try dealer they will want to replace entire cluster.
    LMB Thanks this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    early Version-2 had switch mounted inside gage in instrumental cluster (there were two 4 mm air pipes there), newer have electronic air pressure gauges, sensors are located on firewall oitside ore inside cab (depending on assembly configuration), and addtitional wet tank pressure sensor. Pressure sensors are usually made by Knorr bremse, sometimes Wabco.
    Usually I see sensors on cabover outside the cabin, under grill cover, on conventionals they are usually in center of dash, in park brake valve area.
  6. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Buy a cluster or make a new buzzer yourself
  7. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    Radio shack piezo buzzer soldered onto the cluster for the cheap win. Don't by the loud one, the normal volume one will work fine.
  8. antojakovljevic
    antojakovljevic Bobtail Member
