Low air warning pressure switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by B5love08, Mar 4, 2024.
  1. B5love08
    B5love08 Light Load Member
    68
    38
    Nov 20, 2019
    Not sure if I’m posting in correct place but looking for the location of the low air warning pressure switch on a 1999-2000 freightliner FL-112. Last 6 of vin is A89035.
    thank you
  3. Big Road Skateboard
    7,091
    40,179
    May 2, 2021
    Behind the pedals in the air mainfold.
    Be easy on the tags and you might can still read what each switch is for.
    Heavyd and Rideandrepair Thank this.
  4. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    If it’s not there. Might be on the parking brake. About the size of an old standard round emergency flasher. Should say NC on it. Maybe NC65. Normally closed, opens at 65lbs.
  5. SmallPackage
    5,777
    18,547
    Dec 20, 2019
    Marion Texas
    On that “Business Class” cab they are usually behind the center instrument cluster on a manifold mounted on the bottom of the dash above the peddles. Cannot be accessed at all from underneath.
    Rideandrepair Thanks this.
  6. B5love08
    68
    38
    Nov 20, 2019
    go I have to disconnect all the air lines going to air gauges to remove cluster enough to get hands down in there??? Oh man lol that’s going to suck
  7. B5love08
    68
    38
    Nov 20, 2019
    And chance this is it? Attached to the maxi release knob
  8. SmallPackage
    5,777
    18,547
    Dec 20, 2019
    Marion Texas
    Shouldn’t have too. The air lines and oil pressure line are long enough on mine to pull it to the steering wheel. The oil pressure line is coiled brown plastic hose so it had a little more play on its side of cluster.
  9. B5love08
    68
    38
    Nov 20, 2019
    I posted a picture above, any chance I could luck out and that be it? Before I try to remove dash and look down inside
  10. SmallPackage
    5,777
    18,547
    Dec 20, 2019
    Marion Texas
    That may be it unless it is just a switch to activate the warning light on dash to let you know the brakes are set. Some had that as option.
  11. B5love08
    68
    38
    Nov 20, 2019
    I noticed the connectors were kind of pulled off the sensor and I pushed them back on tight so maybe the light and buzzer will go off. If not guess I’m pulling the dash apart again to look for the manifold. When I looked in there today there was wires and stuff every where and going to have to move a lot I think to expose manifold
