Low coolant warning
Discussion in 'Ask An Owner Operator' started by Randhawa.56, Jun 4, 2021.
  1. Randhawa.56
    Randhawa.56 Bobtail Member
    9
    6
    Jun 4, 2021
    I have a cascadia 2018. Its coolant tank was internally leak so i changed it. And now sometimes it shows low coolant warning and shuts the truck and after few seconds it again good to go while coolant level is good. Any suggestions what could be the problem.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    The sensor and wiring harness going to the sensor are problematic.
    In a pinch you can unplug the sensor so the truck will run (with a check engine light).
  4. Spyro2112
    Spyro2112 Medium Load Member
    621
    430
    Mar 17, 2018
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a whole new tank with sensor. Within two months the sensor failed.
    Yes, you can unplug the sensor as stated. Truck will run fine with check engine light on.
    bzinger and Rideandrepair Thank this.
  6. Randhawa.56
    9
    6
    Jun 4, 2021
    Thnku for the information
    Rideandrepair Thanks this.
  7. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Bought a replacement tank on Amazon and sensor went bad after a couple weeks. Bought a replacement sensor and fixed in couple minutes.
  8. Rideandrepair
    17,514
    56,756
    Aug 8, 2015
    You can jump the plug with a paper clip while it’s unplugged to make engine light go off. That way if there’s another problem, engine will come on to warn you. Also, if you chance you get the same code with it jumped, you’ll know it’s the harness, not the sensor. The harnesses tend to break a wire from flopping around when the fans on. Zip tie it good, to avoid that.
    bzinger Thanks this.
  9. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    The boss had put one radiator and several different sensors. The same one over and over again.
    Then one day it just stopped being hateful. Good luck. These cascadias can be funny sometimes.
