Low gear in high range
Discussion in 'Questions From New Drivers' started by The Counselor, May 16, 2021.
  1. The Counselor
    The Counselor Bobtail Member
    Don't shoot me, I've accidentally discovered a ghost gear. Low while in high range. Is this a bad gear to use while pulling up hill instead of going into the basement?
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    Do what you want. People do it all the time. Mostly in company trucks. However, if eaton intended it to be that way, it would be on there shift pattern. Procede with caution. Would i use that gear in my own truck. Absolutely not. I have an 18 so i dont need it anyway. Just throwing that out there lol
  4. Diesel Dave
    9,643
    32,573
    Jan 20, 2010
    Hesperia, Ca.
    Don’t do it, I’ve been told by the transmission guru that the low gear spins way to fast in high range and chances for it exploding are high.
  5. okiedokie
    okiedokie Road Train Member
    13,839
    109,576
    Jun 13, 2011
    PNWET
  6. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    I've been using that gear for probably 5 years. I often use it when turning corners, faster and easier than flipping to low range.
  7. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    What tranny has this supposed ‘ghost gear’?
    Rideandrepair Thanks this.
  8. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    And when I say I use it often I mean many times a night. I'm a local driver.
    kwt600 and Rideandrepair Thank this.
  9. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    13 and 18 speeds.......
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I am gathering your driving a 13 speed and thinking that there is a gear above first, There isnt
    Diesel Dave and Rideandrepair Thank this.
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    My truck has a 9 spd. I was taught to use that gear leaving a red light bob tail or to ease through a intersection in high range. I never went through a driving school. I have read a lot about that on this forum and decided not to do that anymore.
    Find myself going back to my old habits but thanking about it. 9 speed with 3.70,s on 22.5,s. No load on take off or already rolling at an intersection. Baby footing it. Not much stress on anything that way. Never do that under load or going up hill.
    You are shifting down in gears under load up a grade. The rear counter shaft bearings are small and the number of gear teeth in contact at the same time a few. That is overloading them greatly and you and asking for problems.
