Low oil pressure
Discussion in 'Freightliner Forum' started by Zeeny, Aug 6, 2014.
  1. Zeeny
    Zeeny Light Load Member
    54
    Nov 16, 2013
    Hi can someone help me out,I have a 2000
    Freightliner classic with a 12.7 detroit,it's getting a code 4-5
    and I think it's for low oil pressure but the gauge is reading good
    will anything happen if I push it 20 miles to the freightliner dealer,thank you
  3. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    If your gauge is mechanical roll. If your jakes still work you are getting oil pressure.
  4. Zeeny
    54
    Nov 16, 2013
    Yes it's a regular gauge and the jakes do work,so you think
    its just the sensor
  5. maggard359
    476
    413
    Nov 20, 2013
    Florida
    Yes your jakes will not work without proper oil pressure. Since you have a mechanical gauge reading correctly also I would assume its a sensor. I don't have my book on codes right now but if oil level is good I would roll.
  6. Zeeny
    54
    Nov 16, 2013
    Ok will do thank you very much for the reply
