Lucky break?
Discussion in 'Questions From New Drivers' started by BIGLEFTYINTX, Jul 1, 2020.
  1. BIGLEFTYINTX
    BIGLEFTYINTX Light Load Member
    263
    209
    Nov 20, 2017
    Scale was open NB 35 into Oklahoma, had to pull in to weigh. Scale master after a few minutes, suggested I pull in to inspect driver front inner tire . I did and had to call for new tire .
    How in world can they see other side of truck, especially the inner one ? .
    I'm guessing I got away without A ticket? Heard that is a ticket , driving with a flat tire
  3. D.Tibbitt
    156,857
    So he put u out of service ? What paperwork did he give u. ?
    farmerjohn64 Thanks this.
  4. AModelCat
    164,498
    Someone could have called it in? I've heard they were using heat cameras (FLIR?) in some areas to shoot trucks to spot cold drums (out of adjustment brakes). Maybe the flat tire showed up hotter than the others?
  5. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Yes it is ,and is an out of service violation. Because he "suggested " you check you tire I am assuming he did not conduct an inspection?
    Suspect Zero and farmerjohn64 Thank this.
  6. BIGLEFTYINTX
    263
    209
    Nov 20, 2017
    Was given nothing. I was on the scale and the scale master said over pa , driver, I don't know how far you are going, but I'd suggest pulling in and check out you driver front inner tire. So, I did and called road service for a tire that had a slit in sidewall and was flat
    Suspect Zero Thanks this.
  7. Colt6920
    Colt6920 Light Load Member
    178
    263
    Apr 28, 2017
    I'm guessing they have security cameras/CCTV and can see all sides and angles of your truck.
    D.Tibbitt and farmerjohn64 Thank this.
  8. Flint1
    Flint1 Road Train Member
    1,159
    9,922
    Sep 4, 2019
    Alberta
    In Alberta scale houses have infrared scanners you roll thru on the way to the coop, right after speed limit slows to 10 mph. Diesel bear told me they can detect less then 10 psi difference between 2 tires by heat, as well as hot/cold brakes and hubs. I always was gentle on the brakes before the coop, didn't want to give the bear a bone.
    farmerjohn64 and AModelCat Thank this.
  9. Western flyer
    Western flyer Road Train Member
    2,807
    6,797
    Mar 13, 2014
    They've got cameras that can see all around your
    Truck including underneath of it.
    That's why we roll through at a slow speed.
    There going over are trucks as we roll through.
    They can see flat tires,air lines dragging,missing
    Mud flaps or anything else suspicious to them.
    Now how would I know this.
    I got pulled into the Utah scale on I -15 about 5
    Years ago for running the scale.
    250 dollar fine had to be paid right then in cash.
    Anyhoo, while I'm in there paying the ticket,
    I'm watching all the trucks go by on a big screen
    Television. High definition to boot.
    As they roll by the they've got cameras in the pavement
    That looks up at the bottom of the truck.
    And they can move them around and zoom in
    Up close.
    It's unreal how clear the picture is and how much
    They can see.
    I was shocked.
    They started laughing, they said it's all part of
    This anti terrorist stuff, they can see if you have
    A bomb underneath your truck.
    Now that was about 5 years ago.
    But they told me all new scale houses from
    Then on would have all this stuff.
    Including anything new that comes along in
    The meantime.
  10. Rideandrepair
    17,548
    56,858
    Aug 8, 2015
    He did you a favor, by not putting you OOS. Definitely a Lucky Break.
  11. TripleSix
    133,240
    Yessir. You get more points for a bad tire than vehicular homicide.
