Lug Nuts
Discussion in 'Questions From New Drivers' started by tderrick, Sep 1, 2014.
  1. tderrick
    tderrick Light Load Member
    106
    22
    Jul 26, 2014
    Nashville, TN
    Do you guys carry your own torque wrenches to check for tightness of lug nuts after maintenance or whenever?
    ... or do these rigs typically come with their own tools?
    ...also , what size socket is used on the lug nuts of
    these beasts, typically?
    I'm just starting up a list of "Things to keep in Truck"
    Grazie
  3. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    I don't know anyone that carries a 33mm socket and braker bar to check lug nuts in all my years I've never had one I needed to check!
    Numb, n3ss and tderrick Thank this.
  4. kemosabi49
    10,957
    47,749
    Jan 13, 2013
    SW Arkansas
    You have to carry enough stuff to be prepared for the unexpected. I've been doing this for a while now and have never needed to re-torque lugnuts. Do a good pre-trip and look for the signs of a loose nut. Most shops torque lugnuts when doing work and if they don't, ask them to do it.
    tderrick Thanks this.
  5. 201
    201 Road Train Member
    12,717
    26,160
    Apr 16, 2014
    high plains colorado
    Never had a Budd wheel come off, seen plenty of wagon wheels (Dayton style) come off though. If you see rust streaks coming down the rim from the nut, chances are, it might be loose.
  6. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    53,004
    Dec 8, 2012
    hunting...../ retired
    [QUOTE="semi" retired;4217420]Never had a Budd wheel come off, seen plenty of wagon wheels (Dayton style) come off though. If you see rust streaks coming down the rim from the nut, chances are, it might be loose.[/QUOTE]
    best indicator of a loose lug-nut right there.
  7. okiedokie
    okiedokie Road Train Member
    13,690
    107,971
    Jun 13, 2011
    PNWET
    Hand check a few lug nuts if you see any grease, cracks, ect. Usually it's a loose nut behind the wheel.
  8. tderrick
    106
    22
    Jul 26, 2014
    Nashville, TN
    Thanks for the input, guys :)
  9. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I carry both the 1-1/2" 6-point socket and the 13/16" square socket that I need for my lug nuts. I also have a 40" breaker bar and a 36" cheater pipe. With those, a can of spray lube, and a pair of 30" tire spoons, I can change any tire on my tractor. Just got to remember the left side threads are backwards...lefty-tighty, righty-loosey. Forget that and ya ain't EVER gonna bust 'em loose!
    The trailer is company equipment...and hub piloted. Most I'll do on it is pull off a flat outside tire off the rim with the tire spoons (single it out) so that I can safely drive somewhere for them to have it fixed.
  10. okiedokie
    13,690
    107,971
    Jun 13, 2011
    PNWET
    As long as your mty. Otherwise you'll be over weight on that axle.
  11. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Regs allow you to proceed to a safe location to have repairs made if the defect occurred while underway and it would be safer to proceed than to sit where the defect occurred.
    In other words, as long as the tire isn't throwing chunks all over the road (which it isn't because it has been pulled off the rim) and as long as it isn't capable of coming off the rim and rolling freely down the road (which again, it has been removed), as long as the other tire is in good condition, it is safer to proceed than it is to sit on the side of the road. Yes, I have been pulled over while driving like that by a cop who didn't know any better. After I explained what I was doing and he insisted that I couldn't do it, he called his "DOT guy" and after 45 minutes on the phone with him, he came back, looked at the other tire, and sent me on my way.
    When you know the rules of the game we're playing, it is amazing how many exceptions are out there. DOT sure ain't going to tell you about them, though...
    tderrick and "semi" retired Thank this.
