M11 cummins issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BrotherTruckerA1, Jan 17, 2016.
  1. BrotherTruckerA1
    BrotherTruckerA1 Bobtail Member
    8
    Atlanta, Ga
    I just purchased a 98 international with a 400hp M11 that needs to be nursed back to good health. I've been to 3 different shops but neither could get a signal from either data port (under dash or on the engine itself) to try and pull up any codes to troubleshoot the problem. The truck idles fine but has a skip and puffs white smoke when accelerated. Also only one light comes on in the dash which I think is the engine stop light but I'm not positive. I've checked the external wiring harness with the engine running as best I could to see if there were any change in engine tune and I did find one wire that was maybe grounding out on the frame but that didn't seem to be the problem. Only other thing I can think to do would be to take the ECM off and go have it table tested to see if it will respond off the truck. Any helpful suggestions with this would be greatly appreciated.
  3. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    Look at the wiring that goes to your diagnostic port and make sure nothing is broken, have seen that a bunch of times. The missing and wire smoke tells me air in the fuel or its over fueling.
    BrotherTruckerA1 Thanks this.
  4. BrotherTruckerA1
    8
    Atlanta, Ga
    Yes I figured the air fuel ratio is off too but I'm thinking its in relation to whatever my electrical problem is. The previous owner told me it needs a wiring harness but he's just guessing I want to be sure before I go out and spend $600+.
  5. Cory wood
    335
    162
    Nov 7, 2015
    Yeah that's true, that is what a wiring harness costs and depending on how tight everything is depends on how hard the harness is to get swapped out. You will have to remove the valve cover to unscrew the injector harness from the main harness.
  6. BrotherTruckerA1
    8
    Atlanta, Ga
    If I have to have one put on its going to cummins! I just want to exhaust all my options first.
  7. Cory wood
    335
    162
    Nov 7, 2015
    I wouldn't want to pay that bill, we do it in about 6-8 hours but we are half the rate of cummins.
  8. BrotherTruckerA1
    8
    Atlanta, Ga
    6-8 hrs?? Wow! At $136/hr that can get expensive!!
  9. Cory wood
    335
    162
    Nov 7, 2015
    It's a ton of wiring and hold downs and other wiring to untangle the harness from. Then removing the valve cover and replacing it.
  10. BrotherTruckerA1
    8
    Atlanta, Ga
    Ok, well before I take the ECM can you think of anything else to check?
  11. Cory wood
    335
    162
    Nov 7, 2015
