M2 cat no run problem
Discussion in 'Freightliner Forum' started by All American auto, Jan 2, 2018.
  1. All American auto
    All American auto Bobtail Member
    I have an 2004 m2 with a cat3126,I recently had it lay down on me an I need an opinion on where to start diagnosing this problem.it shut down like I cut off the switch,spins great but no run.i noticed the dummy lights come on with the switch an flicker an fade away to off.cut the switch off an back on an they do that every time.it seems the computer is losing power,I have checked all the batt grounds an power connections at the bat an at the starter.i let it sit for a few hours an tryed it an it fired up an ran great for 7-8 min,then cut off again,what you think?computer? Connection?
  3. rolls canardly
    rolls canardly Road Train Member
    1,635
    4,119
    Feb 7, 2009
    mt. pocono. pa.
    Check your HPOP with a (High Pressure) pressure gage.
  4. rolls canardly
    1,635
    4,119
    Feb 7, 2009
    mt. pocono. pa.
    Oil pressure from "Hi Press. Oil Pump," (HPOP) opens your injectors to fire;
    there is a pressure threshold you have to overcome before they work, (Open).
    My pump failed to reach threshold and did the same thing.
    Replaced it and good to go.
