Mack CXU 613 2011 DPF issues
Discussion in 'Ask An Owner Operator' started by Jestrada0404, Sep 27, 2018.
  1. Jestrada0404
    Jestrada0404 Bobtail Member
    23
    18
    Sep 13, 2017
    Hello , thanks all of you in advance for your help , I have a Mack CXU 613 2011 with MP8 and eaton automatic transmission . My truck just turn on engine light , when I search for code it show me SPN 3556 FMI 4 which mean I am having problems with my DPF , every time I start my engine it start like a passive regeneration that took between 5 to 15 min by itself, this function its not working now , I had been driving around 600 miles since engine light pop up and I am 800 more miles from home , the truck its working as always no problem no losing power or bad gas mileage everything is the same, did not ask for a parked regent , I really don't know what to do ? Help Please , thanks
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Take it to a Volvo shop they will fix it.
    It may be a def dosser valve.
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    7th Injector fault. On the next stop check the harness to the 7th injector. If you can put some dielectric grease in the connector. Then see if you can do a parked regen. If that doesn't work then you are going to have to replace the 7th injector.
    Couple of questions. How many miles? Has this ever been replaced or cleaned?.
  5. Jestrada0404
    23
    18
    Sep 13, 2017
    Hi guys, first of all I want to thank all of you for your msg , I took it to the dealer and they fixed it ,bad 7 injector , they replaced it and problem solved, thanks again
