Mack MP505C
Discussion in 'Ask An Owner Operator' started by HvyHal Gam3ing, May 29, 2021.
  1. HvyHal Gam3ing
    HvyHal Gam3ing Light Load Member
    68
    38
    May 2, 2021
    Angier, nc
    Does any one know if that Mack MP8 505 can be turned up to something like 550 or 565?
  3. Arctic_fox
    4,502
    25,381
    Sep 16, 2016
    Nope 505 iirc is the max the MP8 was able to go upto. If your lacking on power you can see if the torque can be turned to 1860 if its set at say 1650. Or grab a regear. Otherwise there MAY be aftermarket upgrades but pushing a little 13 liter past the max rateing is likely to do bad things to its longevity.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Wouldn't do it. Same exact motor as the volvo D13. People that have em deleted and turned up find out the hard way they don't last. Some crappy tune will be put in and egr disabled and they don't compensate for the extra fresh air being introduced. It will run hot and next thing you know you have a fresh hole in a piston.
    jason6541 and Speed_Drums Thank this.
  5. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    It's already at 1860. Leave well enough alone. If you need 2050 go with a 15 or 16L
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    They say 550hp can be done but it won't be a dealer tune.
    Brettj3876 Thanks this.
