Manifold info
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Apr 8, 2010.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,750
    616
    Feb 21, 2010
    Miami
    Hi My mpg is poor iam thinking to change the manifold How many hours is the instalacion and what brand from the manifold is the best and the price please and what bring the change in mpg and up
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    If you are referring to a diesel engine in a commercial truck, I am sorry to say that by simply changing either the intake or exhaust manifold won't change anything. What kind of truck and engine do you have?
  4. bigrigbuckmaster
    bigrigbuckmaster Light Load Member
    67
    21
    Mar 28, 2010
    Get ahold of one of the following for some good info.
    http://www.fulltiltperformance.com/index.html
    http://www.pittsburghpower.com/
    I've worked with both, always helpful.
    From what I've seen and Heard go with manifold one of these two companies use. Fuel Mileage .3 MPG +
    Price will depend on the type of engine you have.
  5. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    I put one on my 05accert cat from PDI. Went from 4.5 mpg to 6.1 but the factory manifold was leaking from the slip joints so bad it did not want to boost up. Took me about 6 hours to change it. I cant remember the price I think it was about 1200 bucks plus you have about 400 in other parts gaskets studs and such
  6. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
    Iam not a mecanic I have to go in the shop wath is the normaltime for changing the manifold when the manifold bring me 0.5 better mpg iam happy:biggrin_2556:
  7. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    There's only about 8 bolts on the intake anad a couple of hoses and sensorrs to unplug.
  8. bigrigbuckmaster
    67
    21
    Mar 28, 2010
    again, what Kind of engine are you running? If its an Acert then you are going for a full day change out. If a C-15 or E-model it'll be only a few hours.
    There are two brands you can get if you have a Cat Acert or E-Model and those are the Full Tilt Performance ones and the PDI ones. Personally if I were to get a new one again I would go for the Full Tilt.
    pricing for them.
    both a PDI will cost bout 1100
    but Full Tilt has higher flow and lower turbulence though, and Offers a high peformance Ceramic coating that will help keep the Heat down in EGT and underhood temp. also will cause less Looks great and helps with HP and Fuel Mileage more.
    FT also offers a Higher Spec. Studs and bolts that come with.
    For Full Tilt's it will be around 1100 for one uncoated.
    and 1500 coated.
    and like 1650 with a Set of Custom Stainless Steel Spacers that help cause less tension on your mount studs.
    If you have any other type of Manifold, the only place to go is Full Tilt or Pittsburgh Power. And the price varies on the model.
  9. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
  10. bigrigbuckmaster
    67
    21
    Mar 28, 2010
    Get ahold of Full Tilt or Pittsburgh power, they will probably have one on hand or one ready for you within' a week.
    Again, look all the benifits listed above. they will be with also go along with that one. It will be ceramic coated.
    No idea on price. I will figure that out for you. if you want.
    from pictures it looks like it would be a few hour job, but they would know more on that.
    Or if you want, I could find a place around Florida that might have em.
    and feel free to ask more questions...
    gerardo1961 Thanks this.
  11. gerardo1961
    1,750
    616
    Feb 21, 2010
    Miami
    Thanks for helping meaby you find a shop close to Florida or in Florida wath have the manifold with the ceramic Inside.wath can I do after with the old manifold
